2015 subaru forrester/Evo-all
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139486
Printed Date: May 06, 2024 at 10:43 PM
Topic: 2015 subaru forrester/Evo-all
Posted By: prdjr165
Subject: 2015 subaru forrester/Evo-all
Date Posted: September 28, 2015 at 11:53 AM
i can't get the fortin evo-all to program for this 2015 forrester standard key automatic trans.i double checked my connections and everything is connected per the fortin diagram-when i get to the part of pressing the program button 6 times the led's only flash once per second not 5 times per second.i re-flashed the module and even tried a second evo-all module with no luck.
Posted By: tianot
Date Posted: September 30, 2015 at 4:33 PM
did you load the latest firmware version of the evo all? as per the diagram say, you must have hardware minimum version of 6 and minimum fermware version of 79.29.
------------- tianot
Posted By: prdjr165
Date Posted: September 30, 2015 at 5:55 PM
just did that-will be getting the car back this weekend to try again,,thanks !
Posted By: rs specialist
Date Posted: September 30, 2015 at 6:38 PM
https://fortin.ca/en/vehicles/subaru/forester/2015/troubleshooting.html
You may want to check this out when you get the vehicle back.
Posted By: prdjr165
Date Posted: September 30, 2015 at 8:33 PM
Thanks rs specialist,i will do that-I thought i had 2 bad evo-all modules(what's the odds)hopefully the firmware update is the answer!
Posted By: prdjr165
Date Posted: October 03, 2015 at 8:17 AM
i cant figure out how to update the hadware version on the evo-all..i can update the firmware but not the hardware.
Date Posted: October 07, 2015 at 7:05 PM
You can not update the hardware. That is what the evo-all is. if you need updated hardware you need a new module.
Posted By: prdjr165
Date Posted: October 10, 2015 at 9:49 PM
got the new evo-all hardware version 6 today-install went perfect...thanks for the help.
