Remote Starter for 2004 Corolla
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139660
Printed Date: May 02, 2024 at 8:26 PM
Topic: Remote Starter for 2004 Corolla
Posted By: frostyfx
Subject: Remote Starter for 2004 Corolla
Date Posted: November 03, 2015 at 2:46 PM
Hello,
I did a search and didn't find any real walkthrough of how to install a car starter in a 2004 Corolla with pictures and where to connect what. Also I could not really find if I need any sort of bypass module or some key thing.
I did find this wiring but I am in need of some more information.
Posted: November 06, 2004 at 1:33 PM - IP Logged
TOYOTA COROLLA 2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT
WHITE & BLACK
IGNITION SWITCH HARNESS
IGNITION 1 BLACK/ WHITE IGNITION SWITCH HARNESS
IGNITION 2
BLACK / YELLOW
ACCESSORY /HEATER BLOWER 1 BLUE/RED IGNITION SWITCH HARNESS
STARTER RED IGNITION SWITCH HARNESS
PARKING LIGHTS GREEN (+) BOTTOM OF FUSE BOX
PARKING LIGHTS GREEN / WHITE (-) STEERING COLUMN
DOME LIGHT RED / YELLOW (-) INSTRUMENT CLUSTER or DR KICK PANEL *1
DOME LIGHT SUPERVISION COMES ON WITH UNLOCK *1
POWER DOOR LOCK GREEN (-) WHITE PLUG AT RIGHT SIDE OF FUSE BOX *2
POWER DOOR UNLOCK BLUE/BLACK (-) WHITE PLUG AT RIGHT SIDE OF FUSE BOX *2
TACH SENSOR YELLOW /GREEN or RED / BLUE IGNITION COILS or ECM
BRAKE
GREEN / WHITE (+) SWITCH ABOVE BRAKE PEDAL
HORN
FACTORY DISARM
DISARMS with UNLOCK DR KICK PANEL
Any help with pictures and diagrams would be greatly appreciated.
Posted By: smokeman1
Date Posted: November 03, 2015 at 4:16 PM
If you post what brand/model of remote starter you have?
And is your corolla an Auto trans or manual trans?
Power locks? Factory alarm?
------------- When all else fails, Read the Instructions
Posted By: kreg357
Date Posted: November 03, 2015 at 6:41 PM
As for the transponder key, if you haven't tried a $1.99 hardware store copy, try this test : https://www.the12volt.com/installbay/forum_posts.asp?tid=134973
Here is a link to a good source for wire info : https://www.readyremote.com/main.asp?make=Toyota&model=Corolla They have some photo's. ------------- Soldering is fun!
Posted By: frostyfx
Date Posted: November 06, 2015 at 4:22 PM
Thank you for all the replies.
I have tried and the car turns on with a normal metal key. This means that I do not need a bypass module, right?
On the brain of the unit it says
Model #: PD472
Version H4.8 V4.3
Also has a SMARTSTART as a push button logo.
The car is an automatic transmission and it has power locks but I do not believe it has a factory alarm.
Posted By: howie ll
Date Posted: November 07, 2015 at 3:49 AM
Don't know about the other two but I've never heard of it!
Any chance make and model or a more important the units wiring?
Posted By: kreg357
Date Posted: November 07, 2015 at 2:37 PM
+1 New to me. Did a search on PD472 and didn't get anything.
Posted By: frostyfx
Date Posted: November 16, 2015 at 11:39 AM
I will get some pictures of the unit and wiring later today.
I did a search and nothing came up.
