5806 Viper 2009 Pontiac G8 GT Issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139733
Printed Date: May 03, 2024 at 4:23 AM
Topic: 5806 Viper 2009 Pontiac G8 GT Issues
Posted By: nickromo
Subject: 5806 Viper 2009 Pontiac G8 GT Issues
Date Posted: November 16, 2015 at 11:10 AM
Installed a 5806v alarm remote start on my 09 G8 and having a few issues. One issues is that the remote start doesn't crank over, when remote started everything turns on such as accessory and gets ignition ready and then nothing. DBall2 is flashes with latest firmware. Followed wiring off Vipers manual to my vehicle. Also, when remote started the DBAll2 flashes green then red then orange I don't know what that means cant help to issue.
Connections made
Main Harness
Red(Constant 12 Volts)---> Kick Panel Source
Black(Chassis Ground)--->Ground
Brown(Parking Light Isolation)--->NO Connection
WHITE/ Brown(Siren)--->Connected
White(Parking Light Output)--->DBAll2 Controlled
Orange((-)500mA Ground When Armed)--->NO connection
Remote Start Harness
RED / Black((+)Fused 12V acc/starter input)--->Constant 12V at BCM
Pink/Black(+)Flex relay input 87A)---> No connection
Pink/White(+)Ignition 2/ Flex relay output)---> NO connection
Red((+)Fused 12V ignition 1 input)---> org/red wire at BCM at Black Plug
Green(+)Starter Input (key side)--->Dball2 controlled or the issue
Violet(+)Starter Output(car side)--->Dball2 controlled or the issue
Orange(+)Accessory Output)--->Brown wire at BCM Green Plug
RED / White(+)Fused 12V ignition 2/ flex relay input 87)--->NO connection
Pink(+)Ignition 1 input/ output)--->Pink wire at BCM green plug
Aux Harness
DBAll2 Controlled
**** DBall2 controls starter crank I believe because G8 is Remote Start Ready Application.
Dball2 Connections
Gray/Black(+) Accessory output)--->Brown wire BCM Green plug
GREEN/ Black(-)RAP off)--->My mistake connected wrong wire, will connected to driver door pin
Light/Green(Single CAN Wire)--->OBDTHDGM1 harness
Brown(12V)--->OBDTHGM1 harness
Yellow(ignition)---> OBDTHGM1 harness
