Compustar cm7000 False Alarms
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140658
Printed Date: May 28, 2024 at 7:39 PM
Topic: Compustar cm7000 False Alarms
Posted By: bigjohnstud
Subject: Compustar cm7000 False Alarms
Date Posted: January 14, 2016 at 2:48 PM
Vehicle: 2015 Jeep Wrangler
Alarm: (New-Install) Compustar cm7000as w/2W704r-sh long range 2-way RF transmitter
Bypass Module: Fortin EVO-ALL
The only wiring done outside the CAN-BUS are parking lights, siren, hatch trigger and 12v switched connections.
- Doors triggers are connected through CAN-BUS; hood and hatch triggers are hard-wired into Jeep.
- Compustar DAS Tilt/2-stage shock Sensor is currently DISCONNECTED from the brain.
- DEI Proximity Sensor is currently DISCONNECTED from the brain.
About 20% of the time my Compustar will go into full alarm within 5 seconds of arming the system. I thought the issue might have been the proximity sensor so I disconnected it completely. When that didn't work, I also disconnected the DAS tilt/shock sensor with no change (currently no external sensors are connected).
After going into full alarm, pressing disarm turns off the siren but the parking lights continue to cycle through the full timeout period of 30 secs and the doors do not unlock. If I hit disarm a second time, the trigger cycle stops and the doors unlock but there are NO zone breaches indicated on the 2-way remote, by parking light or LED flashes as if the alarm never went off.
When the alarm triggers, I can disarm the system twice, stopping the cycle, and immediately ARM the system with no repeated full trigger.
Thanks in advance for any help you can provide!
