DBall 2 will not program
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141149
Printed Date: May 15, 2024 at 8:43 AM
Topic: DBall 2 will not program
Posted By: pfwillard
Subject: DBall 2 will not program
Date Posted: April 10, 2016 at 7:45 PM
Installed a Viper 4806V in a 2010 Ford Focus with a DBall 2 When I go to program the DBall I cycle the two keys and the LED flashes orange and press the programming button the instrument cluster lights up and the theft light starts flashing and the LED does not turn green.
------------- peter
Posted By: smokeman1
Date Posted: April 11, 2016 at 11:43 AM
More info is needed.
Factory Alarm or not?
Is DBALL2 connected W2W or D2D? Flashed with 402 Ford v3.13?
Please list your connections from the DBALL2 and the Viper 4806.
Are you jumping the ignition wire with 12 volts as described in step 4
------------- When all else fails, Read the Instructions
Date Posted: April 11, 2016 at 6:43 PM
It is W2W and is flashed all connections are per instructions. The thing is when pressing the programming button it will power up the ignition wire.
------------- peter
