I received this as a gift and I would like to just install the remote start only feature for this unit! It would be installed in an 05 Silverado for which I have the wiring diagram. I would appreciate any information I can get with regards to which wiring needs to be installed for the remote start only to function! I am not interested in the keyless entry or C3 teleport features as I would use the factory keyless and the phone feature of my in dash GPS unit. I know that all the wires for the 6 pin connector most likely have to be connected but would like to know which wires for the 5 pin and 14 pin absolutely need to be connected and if there is a need for any relays? Autopage specifies this unit as a "Professional Install". However, if I know which wires are only required and the vehicle locations for terminations for the remote start feature only, I can do this.
I have attached pictures of the of the 5 pin, 6 pin and 14 pin harnesses from the Quick Start Installation Guide for the unit.
Thanks in advance for your help.
Sorry, I didn't realize I could not post pictures!?? Here is the link to the Installation Manual that contains the referenced harness diagrams from the initial post.
https://remotelystartedmn.com/admin_files/PDF/C3RS625instalManual.pdf
Smoke on the Water!
ixvolt, yes, you may post pictures. Use the toolbar directly above the message form.
the12volt • Support the12volt.com
I guess that my firsts pictures were to big!?
Smoke on the Water!
