Print Page | Close Window |
door lock connectionsPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141237 Printed Date: April 29, 2024 at 3:34 AM Topic: door lock connections Posted By: jason556w Subject: door lock connections Date Posted: May 02, 2016 at 12:03 PM Hey guys,
I'm new to remote start installs. I know I can take it to a pro but they're all bad around my place and I thought I'd learn something new. I have a 2010 Rav4 with factory alarm and an Avital 5303. I'm very confused on what to do with the blue and green door lock/unlock harness and the H2-6 pin connector H2/4 and H2/6, which are the factory arm and disarm. Can someone please help, and if it's possible can you guys dumb it down a little please. Lol thank you, guys. Replies: Posted By: kreg357 Date Posted: May 02, 2016 at 3:05 PM Here is the needed wiring for the locks : 1 LIGHT BLUE (-) UNLOCK OUTPUT (+) LOCK ---> Pink (driver door key unlock) double - @ driver kick, white 12 pin plug, pin 9 Additional info : This will take care of both the locks and the Factory alarm, so no need to connect the Avitals' Alarm Arm and Disarm wires. Now for the Avital R/S portion. The Factory Alarm will go off with a remote start ( if the alarm was set ). To prevent this from happening Does the RAV4 have a transponder system ( chipped keys )? Do you have a bypass module? It might be a good idea to list all of your wiring, so the forum members can assist prior to install. ------------- Soldering is fun! Posted By: jason556 Date Posted: May 02, 2016 at 3:29 PM Umm yeah I think it has a a chip so I have a bypass module (it's an O key). I pretty much connected everything when it comes to the main harness, remote start harness, relay satellite, etc. I wad just stuck on the freaking door. When I opened up the system I found a DEI Auto-Mate alarm system installed by the dealer.
The entire time I was sitting there trying to figure out the 6 pin connecter and the 3 pin door lock and now it looks so much easier. And no I didn't connect anything to the rear defogger so I'll connect the keysense wire to it. Oh another question I have is what do I do for the second starter? The RS relay satellite doesn't come with a second starter wire. Do I use a relay to connect it to the main starter wire? Thank you so much though, it means a lot. I really appreciate it. Posted By: jason556w Date Posted: May 02, 2016 at 3:34 PM These are all my car connections-
12 VOLT CONSTANT WHITE ( + ) FUSEBOX @ DASH, PIN 1, WHITE 1-PIN PLUG (G) STARTER YELLOW ( + ) @ IGNITION SWITCH, PIN 8, WHITE 8-PIN PLUG STARTER 2 WHITE ( + ) @ IGNITION SWITCH, PIN 1, WHITE 8-PIN PLUG IGNITION 1 WHITE ( + ) @ IGNITION SWITCH, PIN 6, WHITE 8-PIN PLUG IGNITION 2 PINK ( + ) @ IGNITION SWITCH, PIN 4, WHITE 8-PIN PLUG IGNITION 3 N/A ACCESSORY /HEATER BLOWER 1 RED (+) @ IGNITION SWITCH, PIN 3, WHITE 8-PIN PLUG ACCESSORY /HEATER BLOWER 2 N/A KEYSENSE BLUE ( - ) @IGNITION SWITCH TUMBLER or FUSEBOX,PIN 26, WHITE 32-PIN PLUG PARKING LIGHTS ( - ) WHITE ( - ) @ HEADLIGHT SWITCH, PIN 18, WHITE 20-PIN PLUG PARKING LIGHTS ( + ) GREEN ( + ) @ FUSEBOX, PIN 10, WHITE 30-PIN PLUG POWER LOCK BLUE (-) TYPE B, SEE NOTE #2 @ DRIVERS KICK, PIN 4 ,WHITE 12-PIN PLUG POWER UNLOCK PINK (-) TYPE B (DOUBLE PULSE) @ DRIVERS KICK, PIN 9, WHITE 12-PIN PLUG LOCK MOTOR WIRE RED ( 5-WIRE TYPE ) @ DRIVERS KICK, PIN 6, WHITE 12-PIN PLUG DOOR TRIGGER WHITE ( - ) @ FUSEBOX, PIN 2, WHITE 6-PIN PLUG DOMELIGHT SUPERVISION WHITE ( - ) @ FUSEBOX , PIN 2, WHITE 6-PIN PLUG (K) TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN LT. GREEN ( - ) @ FUSEBOX , PIN 25, WHITE 32-PIN PLUG TACH GRAY (AC) @ DATA CONNECTOR PIN 9, WHITE 32-PIN PLUG WAIT TO START LIGHT N/A BRAKE BLUE ( + ) @ BRAKE PEDAL SWITCH or FUSEBOX, PIN 9, WHITE 30-PIN PLUG(A) FACTORY ALARM DISARM SAME AS UNLOCK WIRE ( - ) ANTI-THEFT TOYOTA'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1 @ IGNITION SWITCH TUMBLER Posted By: kreg357 Date Posted: May 02, 2016 at 3:57 PM Heavy gauge relay satellite wiring diagram To properly power the car's Second Starter wire ( Second Starter White + ignition switch, white 8 pin plug, pin 1 ) you will need a 30/40 Relay Pin 87a not used. ------------- Soldering is fun! Posted By: jason556w Date Posted: May 02, 2016 at 4:15 PM Okay got it.
I also connected the H4/2 (-) 200mA Horn brown wire to my vehicle's horn wire without a relay because I thought that the signal is going to be pretty weak. Should I cut it out and add a relay? Thank you again. Posted By: kreg357 Date Posted: May 02, 2016 at 4:19 PM Shouldn't need a relay for the (-) Horn connection.
------------- Soldering is fun! Posted By: jason556w Date Posted: May 02, 2016 at 4:41 PM Okay, and one last thing-
All my door triggers were separate in the fusebox., So what I did was solder a wire to my H1/8 (-) door trigger input to elongate it. Then I soldered each door trigger to that wire. I also inserted a diode on each wire with the band towards the car and away from the RS. Do you think that's correct? Posted By: kreg357 Date Posted: May 02, 2016 at 4:47 PM Yes on the Door Trigger wires. A 1N4001 diode on each, band towards the car, all joined together at H1/8.
------------- Soldering is fun! Posted By: jason556 Date Posted: May 02, 2016 at 7:56 PM Hi, I dots everything but my car isn't starting. It cranks and quits but nothing else. It doesn't actually start. Please help :(
Posted By: kreg357 Date Posted: May 02, 2016 at 8:14 PM Bypass module? Which one? Did it program OK? Try a R/S with a working key inserted but not turned. ------------- Soldering is fun! Posted By: jason556 Date Posted: May 02, 2016 at 8:30 PM No nothing, the car would crank but not start all the way. Even if I put my key in and try to start it out gives me the same problem.
Posted By: jason556 Date Posted: May 02, 2016 at 8:32 PM And I'm using a DBALL2, I followed all the instructions it came with.
Posted By: jason556 Date Posted: May 02, 2016 at 8:45 PM Okay so it remote starts sometimes, I can't really figure out exactly when. Even my key works sometimes and sometimes it doesn't.
Posted By: kreg357 Date Posted: May 02, 2016 at 8:47 PM That could change everything. We might have to start over. The DB-ALL2 can do a lot more that just handle the transponder bypass. Does your ignition key have a G stamped on the blade? What firmware is the DB-ALL2 flashed with? TL1 or TL2? Are you going D2D or W2W between the R/S and the DB-ALL2? Did the DB-ALL2 program properly in accordance with the steps listed in the install guide? ------------- Soldering is fun! Posted By: kreg357 Date Posted: May 02, 2016 at 8:48 PM jason556 wrote: That shouldn't happen. Adding a R/S should not change the normal key start-up. ------------- Soldering is fun! Posted By: jason556 Date Posted: May 02, 2016 at 9:01 PM No its an O key. Sorry I'm being a hassle.
I'm not sure why the car didn't crank when I first put the key in. Now every time I keep the key in it starts fine. When I take my key out it gives me problems. I'm doing W2w and the lights did flash like the install menu said it would. And honestly the firmware I got from the company I got it from on ebay. They said they'll flash the firmware for my car. Posted By: kreg357 Date Posted: May 03, 2016 at 3:51 AM OK. Here we go. You have a 2010 RAV4 with the Factory Alarm system and the 40 Bit transponder system ( non-G key ). Here is how you proceed. On Page 3 of the TL1 install guide is a chart. This chart gives you two important pieces of info. Next we go to the Type 1 wiring diagram and the supporting pages with the wire colors and locations. But first we have a big Of course at this point we have made a few mistakes. The DB-ALL2 will handle the RAV4's locks and alarm for you but you So, back to the D2D or W2W choice you need to make. In W2W mode you will make hardwire connections between the 5303 Anyway, before we go any further, you need to verify exactly which firmware is loaded on the DB-ALL2. It needs to be TL1 to I apologize for the misleading lock / alarm info provided at the beginning of this post. No mention was made about a bypass module, What you are finding out is that a professional installer has a bunch of knowledge and experience that justifies the installation price that ------------- Soldering is fun! Posted By: jason556 Date Posted: May 03, 2016 at 10:15 AM Oh okay, I actually connected all of the Avital wires including the door locks. I hope the door locks won't be a problem and the Avital connection serves the same purpose as the DBALL2. I connected all of the necessary wires on the bypass module. The wires that were not required in D2D I didn't connect so yeah I'm pretty much operating on data with almost no W2W.
Most of the connections to the remote start I do think I made properly. I used two relays- one for the 2nd starter and one for the domelight supervision. I did connect the parking lights and I did ground all the relays and everything else necessary. And honestly the bypass firmware I'm not sure about because the person I bought it from flashed it for me. Do you think I should change all my bypass connections to W2W? If anything I'll try to pay someone to reflash the bypass since I don't have the loader. Also I don't know if this will help but going through the manual I noticed that the Virtual Tach is the default setting on the RS. I didn't program the virtual tach because I thought that the RS will recognize that I made the Tach connection at the diagnostic port. I'll try to reprogram that to wired Tach,but do you think that is a problem area? Posted By: kreg357 Date Posted: May 03, 2016 at 6:48 PM At this point, you should probably go with DBI D2D between the Avital and the DB-ALL2. While I don't use DB-ALL2's, I have heard First, you should find a way to verify which firmware is loaded on your DB-ALL2. If the EBay seller thought you have a G key vehicle, Next for the wiring. We will go for the basic, bare minimum wiring. ➤ Primary harness (H1), 12-pin connector Auxiliary harness (H2), 6-pin connector ➤ Door lock harness, 3-pin connector
➤ Remote start harness, (H3) 5-pin connector Heavy gauge relay satellite wiring diagram Starter2 relay : Wire connections from the DB-ALL2 to the RAV4 are shown in the Type 1 diagram in solid Black lines from the left side of the module. As you can see, it's pretty simple. Four wires are needed on the Avital H1 harness, none on H2, none on the 3 Pin Door Lock harness, As mentioned, it is possible that the Avital can not handle the Tach and/or the Brake signals via the D2D harness. If you can't get a ------------- Soldering is fun! Posted By: jason556 Date Posted: May 04, 2016 at 12:49 PM Yeah I did most of those connections. I don't have access to a computer right now but when I do I'll give you a write up of every connection I did.
I'll post it either tonight or tomorrow if you don't mind. Posted By: jason556w Date Posted: May 16, 2016 at 12:10 AM Hi, sorry I'm getting back yo you so late. I've been so busy with work and school that I put this to the side.
But these are the connections I did a few weeks ago- ➤ Primary harness (H1), 12-pin connector H1/1 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT Did not use H1/2 RED (+) CONSTANT POWER INPUT Constant power at ignition harness H1/3 BROWN (+) SIREN OUTPUT To siren H1/4 EMPTY NOT USED H1/5 BLACK (-) CHASSIS GROUND INPUT To vehicle ground H1/6 VIOLET (+) DOOR TRIGGER INPUT, ZONE 3 Not used H1/7 BLUE (-) MULTIPLEXED INPUT, ZONE 4 Not used H1/8 GREEN (-) DOOR TRIGGER INPUT, ZONE 3 Connected to all door triggers using diodes H1/9 BLACK/ WHITE (-) 200mA DOMELIGHT SUPERVISION Used a relay, domelight supervision works just fine H1/10 WHITE/ BLUE (-) REMOTE START ACTIVATION INPUT Not used H1/11 WHITE (+)/(-) SELECTABLE LIGHT FLASH OUTPUT White (-) headlight switch H1/12 ORANGE (-) 500mA ARMED OUTPUT Not used Auxiliary harness (H2), 6-pin connector H2/1 LIGHT BLUE (-) SECOND UNLOCK OUTPUT I think I connected this to the keysense like you told me H2/2 WHITE/ BLACK (-) AUX 2 OUTPUT Did Not use H2/3 VIOLET/BLACK (-) AUX 1 OUTPUT Did Not use H2/4 GREEN / WHITE (-) FACTORY ALARM REARM Did Not use H2/5 GRAY/BLACK (-) WAIT-TO-START INPUT Did Not use H2/6 LIGHT GREEN/ BLACK (-) FACTORY ALARM DISARMDid Not use ➤ Door lock harness, 3-pin connector 1 LIGHT BLUE (-) UNLOCK OUTPUT (+) LOCK Connected to door trigger harness behind kickpanel 2 EMPTY NOT USED 3 GREEN (-) LOCK (+) UNLOCK OUTPUT Connected to door trigger harness behind kickpanel ➤ Remote start ribbon harness, wiring diagram 1 PINK/WHITE (-) 200mA PROGRAMMABLE IGN2/ACC2 RELAY TURN ON Not used 2 YELLOW (+) IGNITION INPUT TO ALARM Not used 3 PINK (-) 200mA IGNITION RELAY TURN ON Not used 4 ORANGE (-) 200mA ACCESSORY RELAY TURN ON Not used 5 PURPLE (-) 200mA STARTER RELAY TURN ON to external relay Pin 85 6 ORANGE / BLACK (-) ANTIGRIND/GROUND WHEN ARMED OUTPUT Not used 7 BLUE (-) 200 mA STATUS OUTPUT Not used Handled by D2D harness ➤ Remote start harness, (H3) 5-pin connector H3/1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT connected to ground H3/2 VIOLET/WHITE TACHOMETER INPUT WIREconnected to OBD2 tach input H3/3 BROWN (+) BRAKE SHUTDOWN INPUT WIRE connected to brake switch harness H3/4 GRAY (-) HOOD PINSWITCH INPUT, ZONE 1 not used H3/5 BLUE/WHITE (-) 200 mA 2ND STATUS/REAR DEFOGGER Not used. *** The DB-ALL2 will supply the Hood Status signal only if the RAV4 has the factory hood pin. Heavy gauge relay satellite wiring diagram H/1 PURPLE STARTER OUTPUT (STARTER SIDE) yellow + ignition switch, white 8 pin plug, pin 8 cut wire H/2 GREEN STARTER INPUT (KEY SIDE) yellow + ignition switch, white 8 pin plug, pin 8 cut wire H/3 RED (+) HIGH CURRENT 12V INPUT blue (30A) + ignition switch, white 8 pin plug, pin 7 H/4 ORANGE ACCESSORY CIRCUIT red + ignition switch, white 8 pin plug, pin 3 H/5 PINK OUTPUT IGNITION CIRCUIT white + ignition switch, white 8 pin plug, pin 6 H/6 RED (+) (30A) HIGH CURRENT 12V INPUT blue (30A) + ignition switch, white 8 pin plug, pin 7 H/7 PINK/WHITE SECOND IGNITION CIRCUIT pink + ignition switch, white 8 pin plug, pin 4 H/8 RED / WHITE (+) (30A) HIGH CURRENT 12V blue (30A) + ignition switch, white 8 pin plug, pin 7 |
