Door Ajar light wire from BCM 2007 Mazda 5 GT
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141266
Printed Date: May 12, 2024 at 6:57 AM
Topic: Door Ajar light wire from BCM 2007 Mazda 5 GT
Posted By: kipghost
Subject: Door Ajar light wire from BCM 2007 Mazda 5 GT
Date Posted: May 09, 2016 at 3:19 PM
Hi all!
I've installed a PKE/remote starter/alarm combo but I'm having trouble locating the door ajar wire that lights up the instrument panel cluster's door ajar light without removing the dash and cluster. I know there is a harness that sits on top of the BCM and powers the lights on the cluster/ignition, but I'm still having trouble a finding the dash ajar light wire when testing the contacts in the harness. Can someone please point me in the right direction?
I would use the door trigger wires on the BCM but not all the internal doors switches are normally closed/opened that would be consistent for the alarm's door trigger input. Also, the delay with the dome supervision light going off also makes it not feasible with my setup.
Posted By: i am an idiot
Date Posted: May 09, 2016 at 9:51 PM
No idea where you can find the door ajar light wire. But does that illuminate with the key off?
Audiovox has the following for all door trigger.
All Doors BLUE/RED (-) AT BCM MODULE BEHIND GLOVEBOX TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR PINS AND DIODE ISOLATE EACH WIRE
