identifying car alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141685
Printed Date: May 03, 2024 at 1:23 PM
Topic: identifying car alarm
Posted By: gmls
Subject: identifying car alarm
Date Posted: September 05, 2016 at 1:56 PM
Hi
I recently purchased a 2002 Mercedes CLK convertible to drive arround during the summer.
The car is in a decent state and already fixed some minor issues, did some maintenance and fitted modern stereo with bluethooth etc.
But the car has a terrible aftermarket alarm system. My plan is to remove it during the winter but I wan't to go systematic with it so I need a wiring diagram.
Can anybody identify this alarm system so I can search the web for the diagram
A couple of friens of mine already said the owned car's with the same system so it must be from a knwow brand. (they bought second hand so didn't knwo either)
The alarm disables with a metal thingy that hangs on the key, you have to touch the blinking led next to the steering wheel to disable the alarm, it also has 2 sensors next to the front window
Any help
Thank you in advance
Posted By: gmls
Date Posted: September 05, 2016 at 1:59 PM
Sorry forgot to upload the pictures
Posted By: gmls
Date Posted: September 16, 2016 at 6:04 AM
Finally got time to look at the alarm system, removed both sensors, and traced the wires, found this little box behin the dash
Does annybody knows this box? google didn't find anythig usefull
Posted By: howie ll
Date Posted: September 17, 2016 at 11:46 AM
Defunct Italian manufacturer AFAIK, alarm uses vehicle remote to control it. Probably find that the ultra sonics, above air vent are causing the problem. (Mounted too low, will pick up air movement from those vents).
The round object is a Texas RFID chip, either controls a secondary immobiliser or is an alarm over ride.
