Strange - remote start over D2D?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141700
Printed Date: April 29, 2024 at 5:05 AM
Topic: Strange - remote start over D2D?
Posted By: timmerk
Subject: Strange - remote start over D2D?
Date Posted: September 09, 2016 at 10:38 PM
I know this might sound like a strange question, but is there any product that anyone knows of that can tell a remote starter module such the DBALL2 or EVO-ALL to start the car over D2D? I know both products have D2D ports, but I'm not sure if they support a remote start commands, such as ignition on, starter on, etc, so I was curious if there are any devices out there that could do this so I could test.
Thanks!
Posted By: lurch228
Date Posted: September 10, 2016 at 10:11 PM
On vehicles with OEM R/S Yes, using the 3x Lock with oem remote, using the DBALL/2. DBALL/2 can also do R/S along with the MC501 relay pack, using OEM Remote 3x Lock on vehicles with out OEM R/S.
Then theres the DBALL/2, MC501, XL202, and RF Remote Control kits 9756V, 9856V, and 9656V.
For Viper remote control of All OEM Functions including R/S using the DBALL/2, XL202, and RF Remote Control kits. With the 9756V, 9856V you get 1 mile range with 2 way communication, and the 9656V is 1/2 mile 1 way.
Posted By: rs specialist
Date Posted: September 16, 2016 at 11:23 AM
I believe the MC501 is only for the 4x10 and 5x10 systems
Date Posted: September 16, 2016 at 11:25 AM
Also Fortin and Idata offer solutions for this. They can be vehicle dependent, but if you want remote start from an OEM keyfob on most any vehicle you can use a CrimeStopper RS00-G5. This is what that system was meant for.
Posted By: lurch228
Date Posted: September 16, 2016 at 1:39 PM
Product Description
Dei 4X10/5X10 HI CURRENT RELAY PACK Compatible with the DBALL2Pro the MC501 relay pack allows for easy installation with any traditional ignition system. The relay pack supports ignition sensing in analog and capable of supported very high current loads when required.Product Features
Relay pack allows for easy installation with any traditional ignition system.
Quantity: 1
Posted By: lurch228
Date Posted: September 16, 2016 at 3:19 PM
They have started restricting the functions to higher end products. Like they have done with the 3X lock to start. RXT, and RSR, now the 3x Lock, and RXT is restricted to the 4x10/5x10, AF-D600, DBALL2.
The RSR is now restricted to the DBALL2 only as it is the only choice in the drop down list.
