DEI THGM610C - no W2W?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141721
Printed Date: May 06, 2024 at 5:24 PM
Topic: DEI THGM610C - no W2W?
Posted By: timmerk
Subject: DEI THGM610C - no W2W?
Date Posted: September 14, 2016 at 11:27 PM
The THGM610C's manual states:
"The THGM610 is a GM Plug & Play T-Harness for specific GM vehicles. It can be used in either standalone mode OR with a remote starter in D2D mode (ONLY). The cannot be used in W2W."
Is this accurate? I was doing to use this and a DBALL2 to interface an AdvancedKeys push-to-start system to my 08 GMC Sierra, but I would need W2W connections for the AK unit. However, I'm confused, because this guy seemed to do just that:
https://www.camaro5.com/forums/showpost.php?p=8440135&postcount=74
I thought maybe he was using the THGM610 instead of the THGM610C, but both appear to have the same warning in their manuals.
Thanks for any insight.
Posted By: lurch228
Date Posted: September 15, 2016 at 12:40 AM
This is referring to the connections between the DBALL2 and Alarm/Remote Start OR Stand alone Remote Start. Not other devices that you may install.
