Print Page | Close Window |
2012-2016 Chevrolet Sonic alarm wiringPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141768 Printed Date: April 29, 2024 at 8:28 AM Topic: 2012-2016 Chevrolet Sonic alarm wiring Posted By: comtech5 Subject: 2012-2016 Chevrolet Sonic alarm wiring Date Posted: September 21, 2016 at 1:17 AM Need alarm wiring info on 2012-2016 Chevrolet Sonic. Where can I find this?
Replies: Posted By: lurch228 Date Posted: September 21, 2016 at 3:18 AM The 2012 lists the same as the 2016 but you will still need to verify the proper wire color function and location.
Directwire 2012-2016 Chevrolet Sonic - North America Remote Start, Security, Keyless Entry, Accessories Item Wire / Color / Polarity / Wire Location 12 Volts RED / white (30A) + BCM under driver dash, blue 27 pin plug, pin 4 Starter yellow (for starter kill only) + starter motor or underhood fuse box, black 42 pin plug (X3), pin A2 Second Starter wht/pur (r-code); wht/blk (5V ref) (Tech Doc 1605) +9600 ohms ignition switch or BCM under driv dash, grn 25 pin plug, pins 15, 22 Ignition PURPLE / black + ignition switch or BCM under driv dash, green 25 pin plug, pin 6 Accessory purple / YELLOW + ignition switch or BCM under driv dash, green 25 pin plug, pin 5 Second Accessory (same as second starter) +6300 ohms Keysense (same as second starter) Data Bus GREEN/ purple (immobilizer LIN bus) data immobilizer module or BCM under driver dash, grn 25 pin plug, pin 2 CAN Bus High blue (high speed GMLAN) data data link connector or BCM under driv dash, blue 27 pin plug, pin 24 CAN Bus Low white (high speed GMLAN) data data link connector or BCM under driv dash, blue 27 pin plug, pin 23 CAN Bus SW green (low speed GMLAN) data data link connector or BCM under driv dash, blue 27 pin plug, pin 22 Power Lock BROWN / yellow (center dash switch) - BCM under driver dash, blue 27 pin plug, pin 19 Power Unlock BROWN / white (center dash switch) - BCM under driver dash, blue 27 pin plug, pin 15 Lock Motor BROWN / yellow 5 wire BCM under driver dash, pink 27 pin plug, pin 4 Driver Unlock Motor gray 5 wire BCM under driver dash, pink 27 pin plug, pin 1 Passenger Unlock Motor gray 5 wire BCM under driver dash, pink 27 pin plug, pin 2 Factory Alarm Arm (arms on lock with door open) Factory Alarm Disarm (see disarm no unlock) Disarm No Unlock (Passkey and ignition) Parking Lights (+) PURPLE / gray (L); gray/brown (R) + BCM under driver dash, black 26 pin plug, pins 6, 5 Parking Lights (-) GREEN/ gray - BCM under driver dash, white 26 pin plug, pin 22 Hazards GREEN / WHITE - BCM under driver dash, blue 27 pin plug, pin 26 Turn Signal (Left) blue/white (F); blue/white (R) + BCM under driver dash, brown 26 pin plug, pins 2, 1 Turn Signal (Right) GREEN/ purple (F); blue/purple (R) + BCM under driver dash, black 26 pin plug, pins 3, 4 Headlight WHITE/ purple - BCM under driver dash, white 26 pin plug, pin 16 AutoLights GREEN/ brown (ground to turn off) - BCM under driver dash, white 26 pin plug, pin 11 Reverse Light GREEN / WHITE + BCM under driver dash, gray 26 pin plug, pin 3 Left Front Door Trigger gray (xpress down wndw); gray(xpress up/down wndw) - BCM, pink 27 pin plug, pin 22; driv window motor, blk 7 pin plug, pin 6 Right Front Door Trigger gray - BCM under driver dash, pink 27 pin plug, pin 13 Left Rear Door Trigger gray - BCM under driver dash, pink 27 pin plug, pin 27 Right Rear Door Trigger gray - BCM under driver dash, gray 26 pin plug, pin 11 Dome Light gray + BCM under driver dash, gray 26 pin plug, pin 1 Trunk/Hatch Pin PURPLE / gray - BCM under driver dash, pink 27 pin plug, pin 5 Hood Pin BROWN / green - BCM under driver dash, black 26 pin plug, pin 24 Trunk/Hatch Release yellow/blue (rear handle switch) - BCM under driver dash, pink 27 pin plug, pin 15 Trunk Release Motor GREEN/ brown or gray / YELLOW + BCM under driver dash, black 26 pin plug, pin 12 Tachometer GREEN/ YELLOW, yellow/white, BROWN / pur or BROWN / yel ac any fuel injector, black or gray 2 pin plug, pin 2 Clutch Pedal yellow (see Tech Doc 10001) resistor clutch switch, black 3 pin plug, pin B Fuel Pump PURPLE / black + underhood fuse box, black 72 pin plg (X2), pin J12 Rear Defroster BROWN / purple + latched BCM under driver dash, black 26 pin plug, pin 9 Mirror Defroster (same as rear defroster) Left Front Heated Seat (low speed GMLAN) Right Front Heated Seat (low speed GMLAN) Speed Sense (wheel speed sensor) Brake Wire BROWN / yellow + BCM under driver dash, black 26 pin plug, pin 11 Parking Brake blue/purple - BCM under driver dash, gray 26 pin plug, pin 15 Horn Trigger BROWN / white - BCM under driver dash, brown 26 pin plug, pin 19 Wipers gray + BCM under driver dash, black 26 pin plug, pin 16 Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) yellow/black - BROWN / yellow A driver kick, door harness Left Rear Window (Up/Down) GREEN/ gray - BROWN / blue A driver kick, door harness Right Rear Window (Up/Down) GREEN/ gray - BROWN / blue A driver kick, door harness Sun Roof (Open/Close) GREEN / WHITE - blue/white (funct with ign on only) + sunroof switch, black 4 pin plug, pins 2 - 3 Audio Item Wire Color Polarity Wire Location Radio 12V RED / blue + radio, black 44 pin plug, pin 44 Radio Ground black - radio, black 44 pin plug, pin 38 Radio Ignition (low speed GMLAN) Left Front Speaker (+/-) blue - BROWN / blue +,- radio, black 44 pin plug, pins 40 - 32 Right Front Speaker (+/-) yellow - yellow/black +,- radio, black 44 pin plug, pins 39 - 31 Left Rear Speaker (+/-) green - GREEN/ black +,- radio, black 44 pin plug, pins 42 - 34 Right Rear Speaker (+/-) white - blue/black +,- radio, black 44 pin plug, pins 41 - 33 Aux. Audio Input Left (+/-) gray - brown +,- radio, black 44 pin plug, pins 24 - 23 Aux. Audio Input Right (+/-) green - brown +,- radio, black 44 pin plug, pins 10 - 23 RSE Video (+/-) gray / YELLOW - WHITE/ blue (rearview camera video) +,- radio, black 44 pin plug, pins 7 - 8 Satellite Radio 12 Volts (built into radio) What Fits Item Size Depth Location Headunit irregular center of dash Left Front Speaker 6.5 3.5 left front door Left Front Tweeter 1 left front pillar Right Front Speaker 6.5 3.5 right front door Right Front Tweeter 1 right front pillar Left Rear Speaker 6.5 3 left rear door Right Rear Speaker 6.5 3 right rear door Satellite Radio Tuner (built into radio) Posted By: lurch228 Date Posted: September 21, 2016 at 4:03 AM Tech Tip 10001 GM variable-voltage clutch pedal interface
Some newer GM vehicles have a variable-voltage clutch circuit that consists of three clutch pedal position (CPP) wires: CPP Supply, CPP Return and CPP Signal. Tech Tip 10001 |
