starter install 2016 gmc
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141820
Printed Date: May 15, 2024 at 7:29 AM
Topic: starter install 2016 gmc
Posted By: EWASCHUK
Subject: starter install 2016 gmc
Date Posted: October 04, 2016 at 1:31 PM
just installed a compustar pro-t11 into a 2016 GMC sierra. plane jane truck. only option it has is power locks. The issue I'm having is on the instrument cluster screen a "low battery" alert appears. you can sit with key on and the message wont appear. only when you start it with the key or remote it will trigger that alert. Battery is in good condition and good charge. went to dealership, scanned it, cleared code and tested battery there as well. Any one have an idea as to wheat it may be? only started after the install. thanks in advance.
------------- If You Cant Hear It Before You See It, Whats The Point?
