remote start blinks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141845
Printed Date: May 04, 2024 at 9:30 PM
Topic: remote start blinks
Posted By: ricardoboston
Subject: remote start blinks
Date Posted: October 10, 2016 at 6:44 PM
hello i got a 2008 nissan altima from a customer and he says that he got a new battery replaced on the car and after that, his remote start wouldn't start anymore.so i took the dash off and i have checked the remote start brain and its blinking a lot the red light so i think it get freeze or something happen to the brain, is there anything that i can do to make it stop blinking
Posted By: lurch228
Date Posted: October 11, 2016 at 2:44 AM
Pull all connectors from unit and short positive and negative together.
IF you can get into programming and have all the remotes you can delete all remotes and re-pair them.
If you have a bitwriter you can ZAP it to try and reset it.
Date Posted: October 11, 2016 at 5:21 AM
i did but i did it different i ve ben told to have everything disconnected ground the WHITE/ blue and then get the have gauge back to the brain ? i will try your way thanks
Posted By: lurch228
Date Posted: October 11, 2016 at 6:42 AM
I guessed it is a DEI brand.
IF not post the brand and model
Date Posted: October 11, 2016 at 8:39 AM
avital 4103
Posted By: lurch228
Date Posted: October 11, 2016 at 12:41 PM
Yup same unit sitting here right now. Installed once in a friends car then he got a new car so he had me remove it and I'm waiting on him to install it in his new vehicle.
With unit un plugged you will need to connect Pin H1/8 Black Ground to either or both upper outside heavy gauge Pins.
Date Posted: October 15, 2016 at 8:38 PM
that is like a hard reset, right?
Posted By: lurch228
Date Posted: October 16, 2016 at 1:53 AM
It pulls a residual power from the unit to try and reset last state.
