2015 Highlander LE Code Alarm CA6553
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141871
Printed Date: April 29, 2024 at 6:10 AM
Topic: 2015 Highlander LE Code Alarm CA6553
Posted By: bratok07
Subject: 2015 Highlander LE Code Alarm CA6553
Date Posted: October 16, 2016 at 6:36 PM
hello everyone, I am new here. I have just installed CA6553 on my 2015 highlander. but have a problem with door trigger. I have found (-) input on door trigger and connected it to the alarm but still my alarm sees it as an open door. I also tried connecting (+) input wire of alarm to the trigger still same problem. any ideas?
Posted By: beegbie
Date Posted: October 16, 2016 at 7:01 PM
Give us some more details. What wire are you connected to in the car? What wire on the code alarm is connected to it?
Posted By: bratok07
Date Posted: October 16, 2016 at 7:47 PM
I have connect Green door trigger (-)to the grey wire on white 30pin connector on ECU that reads (ground or 0 volts) when door is open and reads 12v when door is closed.
Posted By: lurch228
Date Posted: October 17, 2016 at 11:51 AM
Test continuity for ground otherwise it is open. Then 12v when closed.
If so you will need to use the dome light for trigger.
As you alarm only has trigger inputs for N/O triggers and can't be configured to do N/C triggers.
Or use a 452D to convert them.
Posted By: bratok07
Date Posted: October 17, 2016 at 5:38 PM
K. Thank you for quick response. I will try the dome light. And will be back with results.
Posted By: lurch228
Date Posted: October 17, 2016 at 9:03 PM
No problem
Posted By: bratok07
Date Posted: November 10, 2016 at 7:30 PM
hey Thank you guys I got the door trigger to work but now I can not figure out the "SAFETY NEUTRAL SWITCH" cannot locate the wire .
help please.
right now when I try to start car with the remote it tries to start but on the dash i have a message, "shift to Park"
Posted By: bratok07
Date Posted: November 10, 2016 at 9:09 PM
Btw here are the wires that i have not connected.
do I have to connect any of this wires?
BLUE/BLACK START STATUS / ACTIVE OUTPUT ( - )
LT GREEN/ BLACK FACTORY DISARM / PULSE BEFORE START ( - )
ORANGE GROUND WHEN ARMED ( - )
BLACK / YELLOW PULSE DURING CRANK ( - )
GREEN / WHITE PULSE AFTER SHUTDOWN ( - )
LT BLUE FACTORY ARM / PULSE AFTER START ( - )
Posted By: bratok07
Date Posted: November 28, 2016 at 8:51 AM
Hey everyone. I have finally finished my alarm. Thnx to my cousin Vlad he hooked me up with factory wirring diagrams. That made my day.
The NSW (neutral safety switch) is a grey wire #6 at ignitions switch, it need 12v during crank, so i just tappped another wire into starte wire and connected to that grey wire. Works like a champ.
