Viper 5706v w/Dball2 to 2001 civic 2door MT
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141886
Printed Date: April 28, 2024 at 6:27 AM
Topic: Viper 5706v w/Dball2 to 2001 civic 2door MT
Posted By: milehighguy
Subject: Viper 5706v w/Dball2 to 2001 civic 2door MT
Date Posted: October 21, 2016 at 5:41 AM
Hello I'm a new member here and this is my first post. I have searched high and low for info on my particular make model car (2001 Honda Civic Coupe MT) along side model viper (5706v) and interface bypass module (Dball2 flashed with firmware HONDA4) wiring specifics and came up with nothing. I'm hoping that questions asked and answered in this forum will be of assistance to not only myself but others having similar issues. If there is already topics out there that cover this i apologize for redundancy but I've spent hours and only come up with make and models earlier or later than 01-05 civic remote start wiring.
I have never installed a remote security system before but feel that i am capable enough for the task with slightly above novice knowledge of basic DIY.
So my issue is I think I've wired this up correctly to the Dball2 Honda4 installation type 3 schematic given along side the wiring diagram i have for my make model and year of my car and everything works besides when i attempt to remote start it's giving an error with 7 count flash code which indicates that MTRS not engaged which i have tried again and again with these steps (while car is on and running place foot on break, activate parking break, open door and within 20sec press command on remote to activate remote start mode. I've done this and still get remote start error. Am i missing something? Maybe I've not wired correctly? Or failed to program dball2 functions or viper functions correctly? And if viper and dball2 are connected does one module take over as primary function programming interface? Because my viper does not seem to want to take any function program with lack of response in chirps or flashes or led indicators. While dball2 seems more responsive to flash # option # led indicators and tends to flash more times than dball2 function are avalable from what dball2 programming instructions state ie 6 functions are all ive seen for dball2 while the led on the dball2 will flash green up to 9x and red up to 6x or 7x i can't remember exactly. So if someone could give me a detailed check list of wire connections from both units to vehicle if there are any relays required for this install and if there are any tips on programming these units initially to activate something I'm missing would be worth many a charitable beer as my thanks for their knowledge and patience as they help me through this process! Much obliged thanks with Paypal donations. Thank you for your time and what you guys do here is above and beyond from what I've read so far!!
------------- We're all sheep
Date Posted: October 21, 2016 at 5:52 AM
By the way I'm using a D2D connection rather than W2W
Posted By: kreg357
Date Posted: October 21, 2016 at 6:46 AM
Two things quickly come to mind.
1. Did you connect the Viper to a proper Tach signal and get a successful Tach Learn? The Viper must be in Tach Mode when running in Manual Transmission Mode.
2. Did you connect the Vipers' BLACK/ WHITE (-) NEUTRAL SAFETY /PARKING BRAKE INPUT wire to the Civics' (-) Parking Brake wire?
Looking closely at the DB-ALL-2 Honda4 Type3 diagram, it appears they omitted a very important wire for your manual transmission install. You might have already caught this error being as you are doing a 5706 Alarm system install. The DB-ALL2 does not supply the Door Status signal. You must make this connection directly from the Viper GREEN (-) DOOR INPUT to the Civics' door pins. These wires are found at the Civics' green Factory Alarm Plug in the DKP as follows : Drivers Door = Green Passengers door = Light Green / Red The above wire colors are on a 4 door Civic and might be different on your 2 door model, so testing is necessary. You will need two 1N4001 diodes for this to isolate theses signals.
The other item not mentioned in the DB-ALL2 install guide is the Clutch bypass. The engine will not crank unless the clutch pedal is depressed. With a R/S install on a manual transmission vehicle, you must temporarily bypass this interlock during a remote start while allowing it to function normally at all other times. How did you achieve this?
There are some other common "rookie" mistakes due to poor / incomplete Viper documentation. If you followed the DB-ALL2 Honda4 Type 3 directions, you connected the Viper thick Pink/White IGN2 wire to the Civics' thick WHITE/ Red ACC2 wire. You must also change Viper Menu 3, Item 8 to Option 2. The Viper has low power (-) ignition outputs on the 24 Pin Connector. These are not used and should not be connected.
Finally, the Viper must see the the Civics' Ignition, Brake, Door Status and Parking Brake signals in a certain sequence to get into Reservation Mode. You should verify all these Viper connections. ------------- Soldering is fun!
Date Posted: October 22, 2016 at 2:34 PM
Thank you kreg357 i think you may have answered everything that i needed to know for this install I'm going to go to radio shack and grab those diodes and get that going and i will update my results as soon as i can! Thank you very much for your time i am very appreciative!!
Date Posted: October 22, 2016 at 3:03 PM
As far as the clutch bypass no i have not and what would you recommend the best course of action in which to achieve this would be?
Date Posted: October 23, 2016 at 2:43 AM
I have bypassed the clutch with a wire to ground with inline toggle switch tested and working. I believe tach is learned w single flash of parking light indicating it's not virtual tach connection. Umm i keep getting remote start error and can't seem to get the car into reservation mode?? Could i have possibly incorrectly connected ignition starter acc from viper instructions? And can you also diagram the diode wire up you mentioned with the green from viper to my door wires thank you!! And if you have a PayPal I'd be more than happy to buy you a few beers for your time and to show my gratitude
Date Posted: October 23, 2016 at 2:49 AM
Sorry never mind on the diode wire up i remember how to do that
Posted By: kreg357
Date Posted: October 23, 2016 at 7:28 AM
Haven't done that Gen Civic for a while. Don't do too many manual transmission vehicles, either.
Basically, you will find two switches and connectors at the top of the clutch pedal. One is to turn off the Cruise
Control and actuates at the beginning of pedal movement. The other is the starter interlock and actuates at the
bottom of pedal movement. You will need a Digital Multi Meter to determine what type of signal is present and how
the switch works. On Honda's, it is typically a low current signal getting passed through the switch when the pedal
is fully depressed. Onced you determine what is there, you can bypass accordingly.
Here is some info that came up with a quick search.
1.) "To bypass the clutch temporarily, apply a low current negative trigger, such as status,
to light-green wire at the switch."
2.) https://www.the12volt.com/installbay/file.asp?ID=1137
The first one sounds correct and can be bypassed easily with a direct connection of the (-) 2nd Status or
(-) Ignition output signal from the Viper.
The second option, using a (+) Clutch Bypass wire at the front of the Fuse Box, I have never tried. That diagram
does give you the location of the Parking Brake wire, Brake wire, Tach wire and Door Pins. I would use the (-) Parking
Light wire at the Headlight switch.
Please test and verify all of this info with a DMM before making any R/S connections.
If the clutch wire you grounded is Light Green, remove the added switch and connect the Viper signal (-) 2nd Status.
To get into Reservation Mode the Viper has to see :
Parking Brake
Brake
Door Trigger
If you haven't connected the Door Triggers, that is probably the reason. The Door Status wire will allow the Viper Alarm to monitor the doors and you need it to get into Viper Programming Mode.
Date Posted: October 25, 2016 at 4:01 PM
This is probably all wrong lol my remote start 10pin harness to my civic brown ignition harness is wired as follows...
Viper-RED / blk fused 12v acc/start input
To
Civic-WHITE/ red Acc
Viper-red fused 12v ign 1
To
Civic-blk / YELLOW ign +
Viper-pink/white ign 2
To
Civic-WHITE/ red acc 2
Viper-green starter input
To
Civic-blk/white cut on key side
Viper-violet starter out
To
Civic-blk/white cut to car side
Viper-Orange acc out
To
Civic-blk/red acc+
Viper-RED / white fused 12v ign 2
To
Civic-white 12v constant
Viper-pink ign 1 input
To
Civic-blk / YELLOW ing+
Viper-pink/blk not connected
Yes that seems a bit off lol
Posted By: kreg357
Date Posted: October 25, 2016 at 8:55 PM
Remote Start, 10-pin heavy gauge connector 2001 Civic Ign Plug
1 NC No Connection
2 RED / BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT White
3 PINK/BLACK (+) FLEX RELAY INPUT 87A key side Not Used
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT Set to ACC2 WHITE/ Red
5 RED (+) FUSED 12V IGNITION 1 INPUT White
6 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL) BLACK/ White
7 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL) BLACK/ White
8 ORANGE (+) ACCESSORY OUTPUT BLACK/ Red
9 RED / WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT 87 White
10 PINK (+) IGNITION 1 INPUT/OUTPUT BLACK / YELLOW
Date Posted: October 26, 2016 at 12:58 AM
Idk what there is left that could be causing this remote start to not activate?? I've isolated the door trigger with diodes and tested both doors to confirm working. I've wired 10pin heavy to your instruction. And tested break and parking break connections with MULTI METER. I've connected tach violet white on 24pin harness to the blue with silver dots found on passenger side of the battery. Maybe I'm missing something on the Dball2 side?? Is the activate wire on the viper supposed to be connected to anything? Or any other wires i may have overlooked?
Kreg357 i really thank you for your patience and response to all this! If you have a PayPal I wouldn't feel right if i didn't buy you a beer or 20 for this or just let me donate to the cause to what ever that cause may be. Thank you
Date Posted: October 26, 2016 at 4:27 PM
Ok so i tried messing with some feature options and tried putting viper into automatic transmission mode and tried engine check mode to virtual and flex relay to ign 2 and it remote starts just stays on for like 30 seconds. My parking lights flash a few times then it dies??
Date Posted: October 26, 2016 at 4:31 PM
Ok i turned the parking light output to constant and now it starts and stays on. Idk it's weird but it works
