Viper 5301 or 4204?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141897
Printed Date: May 04, 2024 at 10:09 PM
Topic: Viper 5301 or 4204?
Posted By: vitaliyk
Subject: Viper 5301 or 4204?
Date Posted: October 23, 2016 at 4:49 PM
I have a question about remote system I just bought.
It is in plastic box. Written “ Viper 2-way vehicle remote start model 5301 2LE. The number on main module is 4X04. Installation guide is given for 4204 model.
Is this should so and what model should be chosen during programming Idatalink bypass module?
Posted By: smokeman1
Date Posted: October 23, 2016 at 5:43 PM
Go with the 4204, Should have a 6 pin main harness, Red, Black, Brown, WHITE/ Brown, White, and Orange wires.
Might have a 9C sticker on the commector
------------- When all else fails, Read the Instructions
Posted By: vitaliyk
Date Posted: October 23, 2016 at 6:21 PM
I have installation guide with wire description. How come in a box 5301 the main module is 4204? I already ordered bypass programmed for 5301. Is it going to be a problem?
Date Posted: October 23, 2016 at 6:32 PM
They are basically the same. The 4204 is a newer version of the 5301
Posted By: vitaliyk
Date Posted: October 23, 2016 at 6:51 PM
What wires should I use? It's programmed for DBI.
Do you have vehicle related wiring diagram for this remote?
Posted By: bat9905
Date Posted: October 23, 2016 at 7:22 PM
Use idatalink website it's all wires and locations . I also use fortin for pics
------------- bat9905
Posted By: vitaliyk
Date Posted: October 24, 2016 at 9:28 AM
Do I need to use door lock/unlock, trunk, honk in and out if DBI connectin is used? Does anybody have list of wires should be used?
Posted By: vitaliyk
Date Posted: October 28, 2016 at 6:09 PM
Looks like they posted wiring with mistakes. pin 26 on black connector is blower motor control. Not accessory+. Pin 16 on M133(fuse box) is fused +12. Definitely cannot be used as light control.
Did they do it in purpose? So where to connect white wire from 6-pin terminal?
Does anybody know the proper wiring for this combination?
