2006 Kia Spectra5 & Viper 5701 Issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142238
Printed Date: May 14, 2024 at 9:38 AM
Topic: 2006 Kia Spectra5 & Viper 5701 Issues
Posted By: matt1981m
Subject: 2006 Kia Spectra5 & Viper 5701 Issues
Date Posted: December 14, 2016 at 3:18 PM
I am installing a Viper 5701 in a 2006 Kia Spectra5 and I am running into some problems. I have not been able to find the door trigger wire. From what I have found, I am looking for a blue/black wire in the drivers side kick panel.
I have just been cheating so far and grounding the wire to allow me t< program features, but that isn't a permanent fix.
I am having issues getting the remote start to work (all wires correctly soldered correctly). When activating, no voltage is put out to the starter over the purple wire. If I disconnect the H3 harness and jump the H6 (+ constant) with H4 (violet starter output) the starter engages.
I did program the unit to be set to automatic transmission mode (3-1-2).
What should I check next?
There is NOT a transponder with this vehicle. I had a non-chip key made at the local hardware store to double check.
