2016 Honda HRV - DBALL2 programing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142256
Printed Date: May 05, 2024 at 8:40 AM
Topic: 2016 Honda HRV - DBALL2 programing
Posted By: thecandyman
Subject: 2016 Honda HRV - DBALL2 programing
Date Posted: December 18, 2016 at 11:01 PM
Hi All,
I have a question on the programing of the DBALL2 for use on a 2016 Honda HRV Push to Start car.
In the programing procedure it says that some vehicles may program the immobilizer bypass in the traditional method with being hooked up to the vehicle, and then some may need to be programed by "Key2GO" method of after failing to program traditional method the DBALL2 is removed from vehicle and hooked up to computer again for the Key2GO programing.
I am wondering if there is a way to know in advance if the DBALL2 can be programed the traditional way ahead of time? I am not able to program it with the Key2GO method, so if my HRV with push to start requires that then I will not be able to program. I don't want to buy the DBALL only to find this out, I would buy another interface module instead of the DBALL2 in this case.
Thanks!
Posted By: beegbie
Date Posted: December 19, 2016 at 8:13 PM
There's no way to tell. In fact, sometimes it won't program at all even with key to go.
Date Posted: December 20, 2016 at 4:16 AM
Thanks, I assumed this was the case but was hoping I was wrong.
Is there another interface module you would recommend for my 2016 Honda HRV push to start?
Posted By: cneubert42
Date Posted: February 05, 2017 at 11:53 AM
any update on this? I have a customer with this same vehicle and I was considering the Fortin all module. guide doesn't show the red flags that the dball2 showed.
Posted By: chev104275
Date Posted: February 05, 2017 at 3:23 PM
I haven't done the truck but Idatalink lists the truck. I don't see anything special
------------- If i Can't Install it I Don't need it Joe
