remove alarm & power cuts out when starting
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142406
Printed Date: April 28, 2024 at 10:42 PM
Topic: remove alarm & power cuts out when starting
Posted By: suga
Subject: remove alarm & power cuts out when starting
Date Posted: January 11, 2017 at 12:24 PM
Removed am Audiovox APS25C car alarm and relay kill switch from a 2003 Mitsubishi Outlander. The problem is when you put the key in the ignition and try to start it all the power cuts out. Have to disconnect and reconnect the battery to get back power but the same thing happens when trying to start it again.
Posted By: i am an idiot
Date Posted: January 11, 2017 at 1:52 PM
You have a bad connection at your battery. Or a dead battery.
Posted By: suga
Date Posted: January 11, 2017 at 2:42 PM
Tbanks for your reply. I didn't think it could have been the battery considering it's just got it 11 days ago. All the connections I have checked and they all are solid.
Notice when I put the key in te ignition and try to start power cuts out and I hear a very slight sound coming from around the fuse box area under the dash. Its there for a little then it stops. Also the sound that the car makes when a door is open, well it goes very fast for a few seconds when I try to start
