mazda 2 car alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142416
Printed Date: May 02, 2024 at 10:07 AM
Topic: mazda 2 car alarm wiring
Posted By: mateo199008
Subject: mazda 2 car alarm wiring
Date Posted: January 13, 2017 at 8:32 PM
i am having issues with my wifes mazda 2 .there is not much information about it ..well i have most of the wires connected ignition wise ...but i am stuck thinking does my mazda need a bypass for the remote car start..because i only have one key for this car ... also i am stuck on the door unlock and lock . i have opened up the door pannel at the switch i see 7 wires for the lock ???
------------- mateo
Date Posted: January 13, 2017 at 9:00 PM
not sure if a relay is needed. i do know it is a type b locking system
------------- mateo
Posted By: wirewise
Date Posted: January 13, 2017 at 9:04 PM
MAZDA 2 2011-2014
KEY T-HARNESS IMMOBILIZER
N/A N/A MAZDA'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (+) WHITE 6-PIN PLUG, PIN E @ IGNITION SWITCH
STARTER BLACK/ BLUE (+) WHITE 6-PIN PLUG, PIN C @ IGNITION SWITCH
STARTER 2 N/A
IGNITION 1 BLACK / YELLOW (+) WHITE 6-PIN PLUG, PIN D @ IGNITION SWITCH
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 BLACK/ RED (+) WHITE 6-PIN PLUG, PIN A @ IGNITION SWITCH
ACCESSORY /HEATER BLOWER 2 BLACK/ WHITE (+) WHITE 6-PIN PLUG, PIN B @ IGNITION SWITCH
KEYSENSE BLUE/BLACK (+) WHITE 2-PIN PLUG, PIN B @ IGNITION KEY SWITCH
PARKING LIGHTS ( - ) BROWN / WHITE (-) @ HEADLIGHT SWITCH or BCM, WHITE 24-PIN PLUG(E), PIN J, See NOTE #2
PARKING LIGHTS ( + ) GRAY/BLACK (+) GRAY 16-PIN PLUG(C), PIN H @ BCM, See NOTE #2
POWER LOCK PINK (-) TYPE B (1-WIRE SYSTEM) DOOR LOCK SWITCH or GRAY 24-PIN PLUG(F), PIN P @ BCM, See NOTE #2
POWER UNLOCK NEGATIVE PULSE THROUGH 1K OHM RESISTOR, SAME WIRE AS POWER LOCK
LOCK MOTOR WIRE RED / BLUE (5-WIRE TYPE) GRAY 16-PIN PLUG(C), PIN M @ BCM, See NOTE #2
DOOR TRIGGER BLACK/ ORANGE (-) GRAY 24-PIN PLUG(F), PIN I @ BCM, See NOTE #2
DOMELIGHT SUPERVISION YELLOW/BLACK (-) GRAY 16-PIN PLUG(C), PIN I @ BCM, See NOTE #2
TRUNK RELEASE USE TRUNK RELEASE MOTOR!!
SLIDING POWER DOOR N/A
HORN PURPLE / RED (-) @ HORN SWITCH or BCM, WHITE 16-PIN PLUG(B), PIN K, See NOTE #2
TACH RED, RED / YELLOW, RED / BLACK or RED / WHITE (AC) GRAY 2-PIN PLUG, PIN B @ ANY FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE GREEN/ YELLOW (+) @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, Harness to Rear of Vehicle
FACTORY ALARM DISARM GREEN (-) GRAY 24-PIN PLUG(F), PIN C @ BCM, See NOTE #2
ANTI-THEFT MAZDA'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1 @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: This vehicle is with MAZDA'S TRANSPONDER ANTI-THEFT SYSTEM,
for REMOTE STARTING ONLY you will need the Part #791 BYPASS Module and an Extra Ignition key. (Requires extra key for Operation)
Part # PK-ALL or PKFM for REMOTE STARTING ONLY, requires 2 keys for programming, NO key required for Operation.
Part # DB-ALL for Remote Starting and Keyless Entry operation (no resistors required), 2 keys required for programming, no key required for Operation.
MAZDA 2 2015-2016
N/A N/A VEHICLES WITH SMART KEY AND PUSH TO START REQUIRES A DBALL2 INTERFACE FOR REMOTE STARTING
12 VOLT CONSTANT WHITE (+) driver kick fuse box
STARTER GRAY (+) Start Stop Unit in steering column, white 24 pin plug, pin 23
STARTER 2 N/A
IGNITION 1 YELLOW (+) Start Stop Unit in steering column, white 24 pin plug, pin 10
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 PINK (+) Start Stop Unit in steering column, white 24 pin plug, pin 2
ACCESSORY /HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) PINK (-) USE HAZARDS Start Stop Unit in steering column, white 32 pin plug, pin 4
PARKING LIGHTS ( + ) N/A
POWER LOCK PINK(-) THRU 1000 ohms (ONE WIRE SYSTEM) BCM above driver kick, white 32 pin plug, pin 6
POWER UNLOCK SAME WIRE AS LOCK (-) BCM above driver kick, white 32 pin plug, pin 6
LOCK MOTOR WIRE TAN (5-WIRE) ESU in driver kick, white 8 pin plug, pin 2
DOOR TRIGGER GREEN (-) BCM above driver kick, white 32 pin plug, pin 20
DOMELIGHT SUPERVISION RED (-) ESU in driver kick, white 18 pin plug, pin 16
TRUNK RELEASE RED (-) BCM above driver kick, white 32 pin plug, pin 10
HORN PINK (-) horn switch, white 14 pin plg, pin 1 or BCM, white 24 pin plug, pin 22
TACH BROWN (AC) camshaft position sensor, engine driver side, gray 3 pin plug, pin 1
BRAKE BLUE (+) Start Stop Unit in steering column, white 32 pin plug, pin 2
FACTORY ALARM DISARM N/A
ANTI-THEFT VEHICLES WITH SMART KEY AND PUSH TO START REQUIRES A DBALL2 INTERFACE FOR REMOTE STARTING
------------- ~wirewise~
Date Posted: January 13, 2017 at 9:23 PM
Thank you that helps me alot.. it looks like I need to get another key tho. Also do you have a pick or diagram of the door wiring with the 1 k ohm resistor? Not sure how to wire that up ?
------------- mateo
Date Posted: January 13, 2017 at 9:26 PM
So I could set my car starter up to open my doors and trunk and bypass the remote starting of the car ? So basically use it for keyless entry ?
------------- mateo
