Viper 5305v doesnt reset after being triggered
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142588
Printed Date: May 03, 2024 at 2:17 AM
Topic: Viper 5305v doesnt reset after being triggered
Posted By: ryaanriot
Subject: Viper 5305v doesnt reset after being triggered
Date Posted: February 09, 2017 at 11:30 PM
Hello all, I'm very new at installing alarms. Long story short Someone gifted me a viper 5305v and i installed it my self. I skipped using all the remote start due to having a 94 civic manual transmission and only installed what i planned on using. The problem is now when the alarm is triggered it does not reset. It gives the 4 chirps every time and the remote shows the door being open and the shock sensor. I did not install the 10 pin heavy gauge connector. Is there something on that connector that needs to be hooked up to have the alarm reset after being triggered? Thank you for you time and advice
Posted By: kaezoo
Date Posted: February 10, 2017 at 4:57 AM
The pink wire in the heavy-gauge harness needs to be connected to the vehicle's ignition wire. Otherwise the alarm can't detect when you switch the key on.
