1991 Dodge Daytona remote unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142717
Printed Date: May 03, 2024 at 11:34 AM
Topic: 1991 Dodge Daytona remote unlock
Posted By: 039C3
Subject: 1991 Dodge Daytona remote unlock
Date Posted: March 05, 2017 at 6:30 AM
I have a 1991 Dodge Daytona base model with factory power locks. The car has a cheap "Spy" alarm/keyless entry/remote start. Reading the wiring diagrams for it, there are two onboard relays for door lock and unlock.
It will remote lock the doors OK but will not unlock them- it tries to do so but it's like there is not enough effort. The inside switches do both OK, although the driver switch was hit or miss. I took it apart and used some 1200 grit sandpaper on the contacts and it is 100% now.
I have attached two diagrams- the OEM setup and what is there now. The car is unusual in that it has only 1 OEM relay- the car will lock the doors once you hit 15 MPH. It has no unlock relay since there was no OEM keyless system installed.
My hybrid wiring is a calculated guess using the relay diagrams here. Using the vehicle database here, I did not find the mentioned wires at the driver kick panel, but did find them behind the body computer on the passenger kick panel. I made use of the OEM wire from the body computer and tapped into it for remote locking. I cut the P/B wire prior to the connector and checked the ends, connecting the switch side to 87a and the motor side to 30.
posted_image
posted_image
Posted By: soundnsecurity
Date Posted: March 05, 2017 at 1:19 PM
hare you tried interfacing the switch directly?
Posted By: 039C3
Date Posted: March 05, 2017 at 3:20 PM
soundnsecurity wrote:
Have you tried interfacing the switch directly?
Do you mean running +12V to the P/B wire from the passenger side switch? If so, yes. It would not unlock both doors, the same partial effort happens. When I disconnected the connector by the kick panel it would unlock the driver side only.
I'm presuming the relay has enough juice to perform the job, it's fed by a 16 G wire that is tapped into the lock power feed.
Posted By: 039C3
Date Posted: March 05, 2017 at 5:39 PM
SOLVED
I had cut the passenger P/B wire after the splice to the passenger motor. Once I ran 2x wires into the door and cut the P/B wire near the switch (before the motor) this resolved the problem.
