2013 kia forte and idatalink
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142743
Printed Date: May 04, 2024 at 10:52 AM
Topic: 2013 kia forte and idatalink
Posted By: trinidad23
Subject: 2013 kia forte and idatalink
Date Posted: March 11, 2017 at 9:45 PM
i want to install an rsautopage777p using idatalink alca module on a 2013 forte with regular key,i have been given different info on the oem security system on this car, some say it does not have a transponder install unless push start , but it does have a remote with lock and unlock plus trunk and if you press the lock twice the horn and all parking and mirrors blink, i want to use the data to data connection and i see on the idatalink webpage schematic for this model#19, THAT ONLY THE SOLID BLACK WIRES NEED TO BE INSTALL, CAN SOMEBODY TELL ME BY LOOKING AT THAT SCHEMATIC IF THAT WILL TAKE CARE OF ANY TRANSPONDER THIS CAR MY HAVE AND ALSO AFTER I FLASH THE MODULE , DO YOU KNOW IF I NEED A LEARNING PROCEDURE FOR THIS CAR, I CHECK ON THE IDATALINK WEBSITE, BUT COULD NOT FIND ONE. THANKS
Posted By: silvercivicsir
Date Posted: March 11, 2017 at 10:58 PM
american Kia's don't have a transponder
Date Posted: March 12, 2017 at 10:34 AM
can you still use the idatalink to limit the wiring install by using the data to data connection? and if so , there where no need to worry about a learning procedure.thanks,if you look at the idatalink website, it gives you the schematic #19 if you don't mind looking at it,showing only a few wires to be connected, i wi be happy to install it this way. thanks again
Date Posted: March 12, 2017 at 11:29 PM
The bypass doesn't do anything for your car (it's only a "transponder" bypass) you have to hard wire everything.. Tach, locks, brake, park lights, oem disarm.
Posted By: chev104275
Date Posted: March 13, 2017 at 7:37 AM
A bypass would do nothing for you in an American made car. The car is not that bad to install in. If you check out the pictorial section there is one there that is 2010-2012 forte but the 13 is the same car.
------------- If i Can't Install it I Don't need it Joe
Date Posted: March 21, 2017 at 11:36 PM
i look at it but is very hard to see clearly, and does anybody has the correct wiring guide for the 2013 forte, not pictorial , ill take it which ever , thanks
