Just got a 1997 F150 and noticed after a while that the it would automatically lock. Looked around and seems to be there was an alarm installed. I have installed some alarms before so im not new but i just can find the model or brand of this alarm. It looks a bit older. Anybody recognize the brand?
My idea was that if i can get the brand or model i can find a remote and program it. All i was able to find on the unit was a FCC ID#:J5523518T1 and google helped me find the remote on the link below. Im not too familiar with the FCC ID so any input from you guys would be great.
https://www.remotesunlimited.com/specify.php?search=1&type=fcc&search_fcc=J5523518T1
There are a lot of remotes on ebay wit the FCC ID of my module. Anybody know if any remote will work?
https://www./sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XFCC+ID+%23+J5523518T1.TRS0&_nkw=FCC+ID+%23+J5523518T1&_sacat=0
The name of the company was Atlas TRC. There is some info on this site on how to program a new remote. I saw a few on EBay that might work. You could try the programming procedure without a remote just to see if the system responds and flashes the Parking Lights. Here is a link :
https://www.the12volt.com/installbay/forum_posts.asp?tid=41884
Might be just as easy to replace it with a current, better quality model.
Thank you for the link im definitely going to try this. Either way i went for it and bought a control from ebay that has the same FCC ID for 6 bucks hopefully it works.
The instructions provided worked. Tooke a couple tries but I now have a working remote with the TRC alarm. One weird thing the lock and unlock are controlled by a single button. Press button 1 and locks press button 1 again and unlocks. Button 2 does nothing. Not that I care much but wanted to mention it in case someone else has to go through this in the future.
Thank you guys.
