External timer to trigger my compustar starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142952
Printed Date: April 29, 2024 at 4:20 AM
Topic: External timer to trigger my compustar starter
Posted By: dsldsl1980
Subject: External timer to trigger my compustar starter
Date Posted: May 09, 2017 at 9:39 PM
I would like to put my remote start on a timer so it automatically starts for me before i leave the office. Could i use something like the timer in the link below to trigger the positive input on my remote start?
FAVOLCANO CN101 DC 12V 16A Digital LCD Power Programmable Timer Time Switch Relay
https://www.amazon.com/dp/B012FSL2GK/ref=cm_sw_r_cp_apa_4HNezbDAT37RE
I'm thinking red pin 11 on connector 2
------------- 11102 West Dana Ln
10
Posted By: silvercivicsir
Date Posted: May 10, 2017 at 4:31 PM
won't work.. why not upgrade to a 2way? If you are within range you could start the car, or use the timer function on the remote..
Date Posted: May 11, 2017 at 8:25 AM
I have a 2 way but I park way to far away for it to work. Can you explain why it can't work?
10
Date Posted: May 11, 2017 at 10:19 AM
Compustar doesn't have a "trigger" wire to enable remote start.. unless you can some how use that timer to send a data signal to the compustar brain it won't work.. your best bet would be to get a drone module. and use the app / pay the yearly fee.
Posted By: kreg357
Date Posted: May 11, 2017 at 4:23 PM
With your CS800-s, a positive pulse on the Red (+) Trigger Start wire will initiate a R/S. My only concern with the Timer unit you suggested is that the shortest pulse it can supply is one minute long. Never tried it with a pulse that long. Before spending the money on that unit, try it manually. Make a fused jumper ( 2 Amp fuse ), connect one end to +12V and connect the other end to that CS800-s Red wire for one minute to see what happens. It might start at the leading edge or the trailing edge. If it works to your satisfaction, go through with the purchase.
------------- Soldering is fun!
Date Posted: May 11, 2017 at 5:05 PM
Sorry my bad, didn't know you had the CM800-s. I assumed you had a Cm7200, CM5200 or a CM6300
Posted By: shift_happens
Date Posted: May 23, 2017 at 11:38 AM
There are diagrams in the relay section on how to convert a latch to a pulse output. They might be helpful if 1 minute pulse length is too long.
Posted By: prdjr165
Date Posted: June 08, 2017 at 5:14 PM
why not get a Drone Mobile installed and start it with your phone...
