Prolock Chip Wire Diagram, 2005 Nissan Armada
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142956
Printed Date: September 20, 2024 at 8:02 PM
Topic: Prolock Chip Wire Diagram, 2005 Nissan Armada
Posted By: bdebee
Subject: Prolock Chip Wire Diagram, 2005 Nissan Armada
Date Posted: May 12, 2017 at 12:03 PM
My chick bought a 2005 Nissan Armada that came with a prolock chip. Like all other prolock chips it worked when it wanted to. She took her uncle to the VA hospital. While he was inside she fell asleep. When she woke up she found that he couldn't get the truck started so he disassembled the prolock chip messed it up completely. Leaving the truck broke down a hour and a half away from where we live. I figured I would be able to figure it out no problem. Needless to say we camped at the truck last night. It had 6 wires 4 were ground and 2 I assume went to the starter. I took it out and saw an orange wire that had been cut which the two wires from the prolock chip were connected to.There also was a light green wire that had been cut and then reconnected with a gray wire. I reconnected the orange wire thinking that would fix it, but when I tried starting it nothing happened. Can someone help me out please ------------- B.Rudd
Posted By: silvercivicsir
Date Posted: May 12, 2017 at 2:50 PM
starter is brown on the armada.. reconnect it but the black wire coming out of the yellow butt connector, and attach it to the blue butt connector
Date Posted: May 12, 2017 at 2:51 PM
starter is brown on the armada.. what happens when you try to start, no crank??
Posted By: bdebee
Date Posted: May 12, 2017 at 3:40 PM
Yeah I saw it was brown upon further inspection. There's two yellow butt connectors which are connected to both sides of the brown wire and then the Blue butt connector is what I use to connect the black wires that was from the prolock chip. I have them connected, however it still won't crank. I can hear clicks now when trying to start where I couldn't b4
Date Posted: May 13, 2017 at 6:03 PM
Sounds like battery is dead
Posted By: bdebee
Date Posted: May 14, 2017 at 7:42 PM
I finally figured it out. After I took the whole dash apart thinking there was a relay or something there wasn't. Called a lock smith out to reprogram the key immobilizer, but it didn't need to be done. It was a relay that had been removed from the hood fuse compartment. I had just about given up when I put a relay in the empty space told my chick to try it and it cranked. Thank you for trying to help. I truly appreciate it and once again thank you.
Posted By: cartronic2u
Date Posted: April 06, 2020 at 5:47 PM
Hi Have you had any more issues with the Armada ?
Or do you even still have it ?
------------- “The bitterness of poor quality remains long after the sweetness of low price"
