Grrrrr Door unlocks using Aux button
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143137
Printed Date: April 30, 2024 at 2:52 PM
Topic: Grrrrr Door unlocks using Aux button
Posted By: chubrok
Subject: Grrrrr Door unlocks using Aux button
Date Posted: July 09, 2017 at 12:33 AM
I have a Python 5706p RS installed on my '14 Tacoma and recently had a 535T window module installed to use Aux1. The problem I am having is that when I hit the Aux button to vent the windows... it also unlocks the drivers door. The alarm stays armed... but the door is now unlocked. Does anyone know how to fix this? Also key fob icon shows "Trunk". Can i change this to "Window"?
Posted By: kaezoo
Date Posted: July 10, 2017 at 8:10 AM
Try turning off "OEM Alarm Disarm w/ Aux-Trunk" (Menu 2, option 6)
The icon associated with AUX can be changed using a Bitwriter.
Posted By: chubrok
Date Posted: July 13, 2017 at 8:11 AM
That was it... Awesome... thanks for the help... the only other problem I am having is that the windows are not rolling up when the alarm is activated. It does roll up when I arm the system... just not when activated... any ideas?
Posted By: kaezoo
Date Posted: July 14, 2017 at 8:01 AM
This might mean that the alarm's siren output wasn't connected to the 535T module, or that the dip switch to select the siren polarity is in the wrong position.
