2017 accord standard key add on using factory fo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143402
Printed Date: May 16, 2024 at 12:51 AM
Topic: 2017 accord standard key add on using factory fo
Posted By: mazda 6t9
Subject: 2017 accord standard key add on using factory fo
Date Posted: July 25, 2017 at 10:45 PM
What is the procedure for unlocking the doors when started via aftermarket system with factory key fobs. Idatalink says to cut the ignition wire but was not very specific on the details on that. I may have to call back on that tomorrow when I am into the vehicle. I know it is says to cut the ignition wire on idatalink ads-al (dl)-ha6-en. But I am not sure how that will fix the issue being he said a relay was needed. I could see if a keyless module needed the ignition cut to not see the ignition to still operate or how Toyotas need the keysense wired in to not see it.
Posted By: beegbie
Date Posted: July 26, 2017 at 5:14 PM
Just follow the guide, no relay needed. Cutting the ignition allows the factory keyless data to be accepted by the immobilizer ring (also the keyless antenna). It then reads those codes and converts them into lock/unlock messages that it sends through can.
Date Posted: July 30, 2017 at 1:34 PM
It worked very well. I had to use the data cable (I mainly use wire to wire but this was pretty slick).
