DEI 530T Install in 9th Gen Civic Si Coupe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143679
Printed Date: May 28, 2024 at 3:18 PM
Topic: DEI 530T Install in 9th Gen Civic Si Coupe
Posted By: daves06xa
Subject: DEI 530T Install in 9th Gen Civic Si Coupe
Date Posted: October 27, 2017 at 3:48 PM
Finishing up my install of viper 5906v with immobilizer bypass and Im trying to incoperate the DEI 530T to roll up windows when arming and using aux. channel to roll up and down. i have driver door panel off and im looking at the connector wires and ive reviewed the 530T install manual. My question is does anyone have the wiring diagram for the 9 gen civic si? I need to know which is switches and motor power for driver and passanger switch. If I ABSOLUTELY need to I could ring all the wires out but that will take awhile. Ive been successful using the resources in this forum thus far so Im hoping someone has already tackled this install. No since in reinventing the wheel.. Thanks again for all your help. If I can help with the viper install feel free to hit me up.. this was my first install and it was very complicated.. especially with push to start and vehicle imobilizer...
Posted By: tonton81
Date Posted: June 27, 2019 at 12:41 PM
dont know if you still need help with 9th gen, i centralized 2 modules piggybacked in the free space in dash behind glovebox, routed 4 wire cabling to each door, i cut the motor wires, switch side and motor side connected to the cable, and did the connections at the glovebox. Works pretty well and runs standalone currently using the PKE2012 keyless from DEI for keyless entry and auto roll up on lock
Posted By: catback
Date Posted: June 28, 2019 at 11:14 AM
I sure hope it doesn't take a year and 8+ months for someone to install a 5906v with a 530T
Posted By: tonton81
Date Posted: July 01, 2019 at 4:46 PM
true, but some people put it aside and forget about it.
This may help others who want to get involved, whether they use it standalone or with an alarm system
Date Posted: July 02, 2019 at 7:17 AM
Wow. Just came in from the garage after connecting the last wire. I just looked at the Calander and I've been out there a year and a half. I lost track of time. Everything works as it should so I guess now I will take it for a drive.
