viper 4916v remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143759
Printed Date: May 19, 2024 at 12:28 PM
Topic: viper 4916v remote start
Posted By: munsie
Subject: viper 4916v remote start
Date Posted: November 11, 2017 at 3:56 PM
I have a 2008 ford f350 with the 6.4 no chip in key
I installed the remote start but all it dose is flash the light 10 times I don't know where to go with this any help? am I missing something
------------- just another day
Posted By: munsie
Date Posted: November 11, 2017 at 4:17 PM
sorry its a 4816v
Posted By: geepherder
Date Posted: November 12, 2017 at 4:02 AM
Is the toggle switch in the "on" position (and installed)?
------------- My ex once told me I have a perfect face for radio.
Posted By: munsie
Date Posted: November 12, 2017 at 11:22 AM
Do not see a toggle switch or a spot for one it has a thing called a control center and that works
Date Posted: November 12, 2017 at 6:13 PM
https://www.crutchfield.com/S-C5lUxBmBsMj/p_6074816V/Viper-4816V.html#&gid=1&pid=2
If you select the second picture, you'll see the 2-pin switch I'm referring to.
https://www.directeddealers.com/manuals/OG/Viper/G4816VML%202015-08%20web.pdf
If it's 8 flashes and not 10, the owner's manual lists "toggle switch off" under remote start faults.
Do you see the black unused 2 pin port on the same side as most of your other harnesses? Try something like this:
https://frys.com/product/1350536?site=sr:SEARCH:MAIN_RSLT_PG
Posted By: munsie
Date Posted: November 12, 2017 at 6:58 PM
It’s not there that I see ------------- just another day
Date Posted: November 13, 2017 at 6:07 AM
Okay. I'd double check the number of flashes, then. The manual has nothing listed for 10 flashes.
Posted By: munsie
Date Posted: November 13, 2017 at 7:50 AM
Ok so I went through and found out that the ten flashes was because I was activating car finder so now that I know that it flashes the lights 7 times and help with that ??says something about manual transmission mode but I don’t see a wire for that?
Date Posted: November 13, 2017 at 1:28 PM
If your vehicle is automatic, it needs to be programmed as such. Manual is the default. Menu 3 option 1.
Posted By: munsie
Date Posted: November 13, 2017 at 3:25 PM
I feel like an idiot.
I got it switched to auto.
Now it turns on the the ign and acc but does not crank? Gerrr! 😤
Date Posted: November 13, 2017 at 5:46 PM
Which wire from the remote start do you have connected to which wire in the vehicle for your starter connection? Have you tested these for proper voltage when you try to remote start?
Posted By: munsie
Date Posted: November 13, 2017 at 6:06 PM
I connected the violet wire to my truck for the starter when initiating remote start there is no voltage coming out of the box to my truck if I send power to it it does crank over and start
Posted By: tdbaker021
Date Posted: November 13, 2017 at 7:12 PM
Did you ground the neutral safety wire?
Posted By: munsie
Date Posted: November 14, 2017 at 5:13 AM
Do not see a neutral safety wire
Date Posted: November 14, 2017 at 8:20 AM
Good call, tdbaker021.
https://www.directeddealers.com/manuals/IG/Viper/N4X06%202015-12%20web.pdf
It maybe labelled as a parking brake wire, but it needs to be grounded. Black/white pin 13 of the 24 pin harness.
Posted By: munsie
Date Posted: November 14, 2017 at 8:31 AM
The black and white for parking brake is grounded
Date Posted: November 14, 2017 at 5:42 PM
Then it's likely the unit's no good. Being as such, there is no warranty, as you're installing it yourself. It wouldn't hurt to open it up and look for something obvious.
Posted By: munsie
Date Posted: November 15, 2017 at 8:26 AM
Well good news is I got it to work had to change the crank time and use the flex relay setup. Also the ground I had for the parking brake was not good hooked it to the ground for the unit and works awesome now just need to change my run time. Thanks for the help!!
