Wiring hack to auto fold mirrors with RKE 2010 C
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144117
Printed Date: May 16, 2024 at 9:49 AM
Topic: Wiring hack to auto fold mirrors with RKE 2010 C
Posted By: finallyac-1500
Subject: Wiring hack to auto fold mirrors with RKE 2010 C
Date Posted: February 02, 2018 at 1:31 PM
After searching the forums, I found only one post that was similar to my question, here: https://www.the12volt.com/installbay/forum_posts.asp?tid=136352
My mirrors, locks and auto start are all factory. Later models you simply program the fold to the lock in the DIC. No such option in the 2010 model. It looks like it should be simple to wire in. Wish I was smarter! Thanks
Bill
------------- I still have so much to learn.
Posted By: geepherder
Date Posted: February 02, 2018 at 5:31 PM
What is the year, make and model of the vehicle?
------------- My ex once told me I have a perfect face for radio.
Date Posted: February 03, 2018 at 12:42 AM
2010 Chevy C-1500 LTZ. Sorry I omitted that info!
Date Posted: February 03, 2018 at 6:17 AM
I'm assuming there's a button used to fold the mirrors. Do you have to press/hold, or just press/release? If it's just a momentary press, maybe you can simulate a button press using a relay controlled with the ignition. This probably requires disassembly of the switch and soldering some small wires inside. If you go this route, I'd buy a spare switch before attempting.
Alternatively, you could go directly to the motor wires, and use a window module, or something similar. It looks like the yellow and light blue wires are what you need: https://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=176393
Posted By: howie ll
Date Posted: February 03, 2018 at 10:06 AM
That's the safest.
Here's another:-
And another!:-
DE3_mirrors.bmp------------- Amateurs assume, don't test and have problems; pros test first. I am not a free install service.
