2003 Suburban Remote Start issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144225
Printed Date: May 15, 2024 at 10:40 AM
Topic: 2003 Suburban Remote Start issues
Posted By: th3cavalry
Subject: 2003 Suburban Remote Start issues
Date Posted: March 10, 2018 at 11:36 PM
Hello all! I just completed remote start on a family member 03 Suburban however I ran into an issue and I have a question.
Issue: When starting the vehicle using remote start, the brake warning light comes on and a "service 4x4" message pops up on the dash information system. The vehicle drives fine without any issues.
The RS is an Automate AM7. The bypass module is a GMDLP.
I also would like to completely disable the factory alarm since I am using the AM7 system, but I can't find any information on how to do it.
Thanks!
Posted By: kreg357
Date Posted: March 11, 2018 at 2:49 PM
Did you power the Surburbans' White Ignition2 wire as Ignition2?
------------- Soldering is fun!
Date Posted: March 11, 2018 at 2:52 PM
Yeah I did
Posted By: kreg357
Date Posted: March 11, 2018 at 3:20 PM
And the two ACC wires, Brown and Orange?
Got to be something going on due to a difference between a R/S and a Key start.
Date Posted: March 11, 2018 at 6:03 PM
Two ACC wires? I only read about the main IGN and the secondary for the trans.
Posted By: kreg357
Date Posted: March 11, 2018 at 8:01 PM
Well, if you don't have those issues with a regular key start, I would think it
prudent to try and duplicate that ignition wire sequence with a remote start.
Posted By: howie ll
Date Posted: March 12, 2018 at 5:01 AM
And in a few weeks you can say goodbye to your transmission and lots of $ unless you connect.
