2006 Silverado Bypass Module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144954
Printed Date: May 10, 2024 at 2:36 PM
Topic: 2006 Silverado Bypass Module
Posted By: white190
Subject: 2006 Silverado Bypass Module
Date Posted: November 17, 2018 at 6:55 PM
I currently have a GMDLBP module wired in and all works correctly. When ignition is shut off, 10 or 15 seconds later, the module locks the doors and also triggers the retained accessory power to shut off. I don't want this to happen. I have tested without the alarm/remote start plugged in, so the bypass is definitely triggering the locks. Is this just a "feature" of the GMDLBP? Is there another bypass module that anyone has used that doesn't do this?
Posted By: lurch228
Date Posted: November 21, 2018 at 12:49 AM
Programming Option Mode
Tech Notes
Tech Tips
1-Press and hold the Programming button for 2 seconds. The LED will flash for approximately 3 seconds, PAUSE,
then flash once more to indicate entry into MODE1 (DOORLOCK SELECTION).
2-To advance to next MODE, press the Programming button again. The LED will flash to confirm what MODE you
are in. Ex: 1 flash = MODE 1, 2 flashes = MODE 2, and so on...
3-Once you have entered the required MODE: you may then change your options. Advance the OPTION by
pressing the LOCK or UNLOCK button from your aftermarket transmitter.
4-The vehicle will chirp once (1X) or twice (2X) to indicate option level.
5-To exit the OPTION PROGRAMMING: Press and hold the program button until the LED flashes once (1X).
6-To return or change another OPTION, go to step 1.
OPTION PROGRAMMING CHART
Mode Selection Option Programming *Default Value
Mode1:Doorlock output *Option 1: 1st PULSE: Driver Priority Function
2nd PULSE: Unlock all doors
Option 2: 1st PULSE: Unlock all doors
Complete GMDLBP.pdf here:https://dalhems.com/f/d/30faa7a0c62a479b90059f9d00efb91c/1646_GMDLBP_H02_S05_D01_I_EN.pdf
Posted By: white190
Date Posted: December 01, 2018 at 9:54 PM
I have the module all programmed and working. My issue is that even not using remote start, not long after the truck is turned off, the bypass module is commanding the doors to be locked and shuts off retained accessory power. It does so without the alarm connected, so it's definitely the bypass. Without the bypass, after shutting off the truck, the doors stay unlocked and my retained accessory power stays on for I believe 10 mins. It seems that this is how this specific bypass works and I'm wondering if there is one that behaves just like stock.
