Recognize this AstroStart HG? Remote Pairing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145969
Printed Date: May 28, 2024 at 6:34 PM
Topic: Recognize this AstroStart HG? Remote Pairing
Posted By: hiflier68
Subject: Recognize this AstroStart HG? Remote Pairing
Date Posted: January 23, 2020 at 8:48 PM
I have looked for hours to find any install information on this remote start..
One side of the box says "AstroFlex" the side with the schematics says "AstroStart model HG part No.392-127-302 rev1 *HG1481970*
Purchased at auction and found this installed. Need to find the correct remote and figure out how
to program. I have found the "Users Manual" from Directed. Not sure if its the correct one though.
Purchased a used remote, and tried dip switch 8 process, no luck. Though there is no Hood pin
and I didnt have time to ground the Gray wire.
I have pictures but not sure how to post here if we can.
HELP
Mitchell
Posted By: motosaki
Date Posted: January 24, 2020 at 8:29 AM
astro start 2106, or astro start 2514 will program to that brain.
------------- 15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
Posted By: silvercivicsir
Date Posted: January 24, 2020 at 11:34 AM
Flip Dip switch 8 down,---> press the brakes. ---> press lock on the remote, does the led on the brain flash? it should if it learned the remote.. I assumed you check to make sure the module has power/ ground?
