AstroStart Model Identification
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146568
Printed Date: May 09, 2024 at 5:41 PM
Topic: AstroStart Model Identification
Posted By: bknewport42
Subject: AstroStart Model Identification
Date Posted: November 22, 2020 at 3:23 PM
Posted By: iskidoo
Date Posted: November 22, 2020 at 8:36 PM
Posted By: iskidoo
Date Posted: November 22, 2020 at 8:56 PM
Looking at this post and looking at whats left of your sticker I think its the one that ends in 317 REV1 BBW
https://www.the12volt.com/installbay/forum_posts.asp?tid=131744------------- Steve G
Posted By: iskidoo
Date Posted: November 22, 2020 at 9:07 PM
If you get this working you should mount the antenna on the windshield. Having it under the dash really limits the range.
I uploaded the install manual for you that I found with google. Transmitter programming on page 27
AstroStart BBW install manual------------- Steve G
Posted By: iskidoo
Date Posted: November 22, 2020 at 9:57 PM
Can you look to see if there are any frequency numbers printed on the antenna case?
Posted By: iskidoo
Date Posted: November 22, 2020 at 10:28 PM
Posted By: iskidoo
Date Posted: November 22, 2020 at 11:36 PM
Found an ebay auction that has the brain and remotes together so thats good. Makes it easy to figure out the exact remotes that came with that BBW system.
Remotes have FCCID: NJQ372HAF on them.
https://www./i/264942543307?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=264942543307&targetid=882300791467&device=c&mktype=pla&googleloc=9002593&poi=&campaignid=1669934603&mkgroupid=65058347419&rlsatarget=pla-882300791467&abcId=1123856&merchantid=6296724&gclid=CjwKCAiAtej9BRAvEiwA0UAWXg8lUgKQbLp3pAsbJFdoQDl4vquF3ykeNB9C2fNd7QH82LkGX1lv9BoC3dwQAvD_BwE
So you can use this LCD one here LCD Remote https://www.keylessentryremotefob.com/astrostart-NJQ372HAF-4-button-screen-key-fob-p/astro%20njq372haf%204btn.htm
Or this LED remote LED Remote
https://www.keylessentryremotefob.com/astrostart-NJQ372HAF-5-button-keyless-entry-remote-p/astrostart%20njq372haf%205btn.htm
This should be the Owner's Guide for that outlines the functions for the remote transmitters.
AstroStart 4204A Owners Guide
I should be a CSI;) ------------- Steve G
Date Posted: November 23, 2020 at 12:23 PM
I will try to see if there are any on the antenna, and let you know, thank you.
------------- Bryan
Date Posted: November 23, 2020 at 1:12 PM
Ok, I got more pics of the antenna, but with the way it was mounted, I can tell if it even ever had any markings or numbers on it, but here they are.
------------- Bryan
Posted By: geepherder
Date Posted: November 23, 2020 at 3:14 PM
Some adhesive remover and elbow grease will get rid of the mounting tape. Then you can see the numbers underneath.
------------- My ex once told me I have a perfect face for radio.
Date Posted: February 20, 2023 at 8:26 AM
I have cleaned and looked at the antenna, and there are no visible marks and if there were any stickers, they were prior to me owning the unit.
------------- Bryan
Date Posted: February 20, 2023 at 8:29 AM
my nest question. How are the dip switches supposed to be set. All of mine are in the down, or off (?) position. ------------- Bryan
Date Posted: February 20, 2023 at 9:39 AM
Well I won't be any help, then.
Date Posted: February 22, 2023 at 5:19 PM
OK, iskidoo, I did not find any printing or numbers on the back of the antenna, but there is a screw in the center of it, if I took that apart, would the board tell me what is needed to know for the frequency numbers?
------------- Bryan
