2010 Nissan Sentra, Remote Starter Bypass Issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147682
Printed Date: May 30, 2024 at 8:39 AM
Topic: 2010 Nissan Sentra, Remote Starter Bypass Issue
Posted By: greengiant2023
Subject: 2010 Nissan Sentra, Remote Starter Bypass Issue
Date Posted: May 26, 2023 at 3:31 AM
Hello everyone,
I installed remote start on my 2010 nissan sentra last fall, but for some reason the bypass doesn't wanna work with the car. I have 2 different modules. idatalink ADS-ALCA I can't remember the model of the other idatalink. I'll see if I can find the box.
One says it accepts the programming. One doesn't accept programming (ADS-ALCA). Just flashes red
Will start find if the key is placed in the ignition. And stay running when removed.
Any insight into what I have done wrong?
Regards
Posted By: kreg357
Date Posted: May 28, 2023 at 8:52 PM
A few questions :
1. What brand / model R/S system?
2. Are you going W2W or D2D between the R/S and the iDatalink module?
3. Did you flash the correct firmware onto the iDatalink module ( NI-4 )?
4. Did you set the iDatalink Installation Mode prior to vehicle programming?
------------- Soldering is fun!
Date Posted: May 29, 2023 at 1:48 PM
It's a Autostart system. I have tried both hardware mode and 2 way modes. Get same result. I had bought the USB connection for the idatalink module, and programed it for a 2010 Nissan Sentra with intelligent key I believe it was called. It as been a while since I done anything with it.
I've tried reseting the idatalink reprogramming it. The lights flash saying it ready to accept programming. One does what it's suppose to do, and the other just flashes red lights
Posted By: silvercivicsir
Date Posted: May 29, 2023 at 1:55 PM
do you have a key that in stick in the ignition? or is it push to start? the Intelligent key is either Push to start, or "nissans key tumbler" you turn.. all others is standard key.. Also for the autostart, set the Protocol on the al-ca to DBI, and you can use either the ADS/DBI port on the Autostart, either works...
Date Posted: May 29, 2023 at 3:40 PM
It's a key you have to insert.
Date Posted: May 30, 2023 at 9:15 AM
if it's a key you insert and turn, it's the Standard key, not intelligent key. so you have the use the clock wire, and immo data wire..
Date Posted: June 01, 2023 at 11:48 AM
Okay thanks, I'm on shift right now. I'm hoping to have time on my days off....
Date Posted: June 04, 2023 at 6:16 PM
I managed to get at this between rain.
Sorry guys it's not a Autostart, it's a prostart.
I flashed the ADS-ALCA to Firmware: DBI-AL(DL)-NI4 v1.8, and chose DBI, 2 way mode and hardware mode. Each time when programming the key, as soon as you turn the key forward it starts flashing red. It's stays this way until you reset it, and keeps doin that.
I flashed the ADS-DLSL CA2(I assume same firmware, forgot to take a picture), for 2 way mode and hardware mode. It doesn't have a DBI option. When you turn the key forward it flashes green and goes out, so accepts programming. But when you try to start it with the remote start lights come on but won't crank over. Noticed today that no lights come on the module when I press the start button. According to the guide it say it's not getting the ground while running.
I'm totally at a loss right now. Not sure what else I can do.
Date Posted: June 23, 2023 at 3:07 PM
did you figure this out?
Date Posted: July 07, 2023 at 1:28 PM
No I did not. I gave up on it, I'll just have to leave the key in the ignition when it gets cold again.
