1997 GMC Sierra, Door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147811
Printed Date: May 14, 2024 at 5:44 AM
Topic: 1997 GMC Sierra, Door locks
Posted By: fplasma@live.ca
Subject: 1997 GMC Sierra, Door locks
Date Posted: December 03, 2023 at 11:22 AM
Hello, I am just wondering if anyone can help me out tying my electric door locks into my starter/alarm. I have searched the 12 wiring diagrams as well as other people who have had questions/issues with the same problem. On the 12 volt install wiring diagrams it says to use light blue and white for lock and unlock, I have located those wires near my drivers kick panel but they do not activate my locks, when I test them it appears the light blue wire goes to my right rear speaker and the white wire goes to my brake relay in the engine bay. Upon further searching on the 12 volt and online I have seen a few people say that it is a tan and gray wire for lock and unlock (I may have them wrong as far as lock and unlock but it does list those color's) however I can not locate those wire color's in drivers kick panel. Somewhere else I saw someone listing black/red and gray but I also can not locate those wires either. I am just wondering if anyone can help steer me in the right direction, I have the install mostly completed but would like to get the locks working properly. Any advice or support would be greatly appreciated, thank you.
Posted By: kreg357
Date Posted: December 03, 2023 at 12:23 PM
Looks like some additional testing is in order.
The truck can either have Type A or Type C door locks. If the truck came from the factory with OEM Keyless entry it should have Type A (+) door locks. If it did not come with factory keyless entry FOB's, then it's Type C (5 wire REV).
Here is a link to the DEI Door Lock system guide : https://www.the12volt.com/installbay/file.asp?ID=708
It will explain the differences, how to test and determine which type of locks you have and the necessary wiring. Your best bet is to obtain a DEI 451M door lock module. It will change the R/S systems (-) Lock outputs to a (+) for Type A locks and also handle Type C locks if needed. Here is a link to the 451M install guide : https://www.the12volt.com/installbay/file.asp?ID=726
The 451M module can be found at various on-line sellers for under $20. If you like to solder, you can get two 30/40 Amp SPDT relays with the 5 wire harness and a 15 Amp fuse holder assy and make your own 451M for a little less.
Here is the info on the lock wires you are looking for :
Lock L BLUE in DRIVER KICK PANEL
Unlock WHITE in Drivers Kick PANEL
------------- Soldering is fun!
Date Posted: December 03, 2023 at 10:00 PM
Thank you very much. It was a type C, I hooked up a couple relays got got everything working. Thx again.
Posted By: kreg357
Date Posted: December 04, 2023 at 11:28 AM
Good news. Thanks for the update!
