No LED At Astro Flex Box, 2013 Honda Civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147815
Printed Date: May 10, 2024 at 11:59 AM
Topic: No LED At Astro Flex Box, 2013 Honda Civic
Posted By: principal8282
Subject: No LED At Astro Flex Box, 2013 Honda Civic
Date Posted: December 05, 2023 at 6:19 PM
I’m a complete newb.
School principal with a warm garage and desire to help dear daughter. I have a meter and other basics but lack a lot of basic knowledge.
She has a 2013 civic. Hit a deer. Body work all done. Looks great.
Car is automatic trans, passkey, turn key to start. System did work fine prior to the collision. I think body shop forgot to set up a hood pin.
We now have non working remote start and now some sort of weird parasitic battery drain.
I would take it anywhere. We live in the bush. It’s 100 miles to a town of any substantial size. 25 to another small town with a mechanic who can look…maybe next week
I cannot even get the led to illuminate to the box.
It’s an Astro flex BBK. Professionally installed at a car dealer. Said dealer is 110 miles away.
Thanks in advance
------------- Nick
Posted By: silvercivicsir
Date Posted: December 06, 2023 at 6:46 PM
Start by metering the Red and Red/Black wires on the Asto Flex, to see if the unit has power. If no Power, check the fuses 1st. Next check the Black wire from the Astro Flex to check for ground. Next Meter the Blk/red wire, it should be "OPEN", if it's grounded, there is your issue.
Date Posted: December 09, 2023 at 6:44 AM
I just saw this.
I have been having issues with a parasitic battery drain. Last night I disconnected the module for Astro start. No more overnight drain as measured by voltmeter.
I am going to see if blk and red is open or ground.
It was in a deer collision this fall. I bet the hood pin wire is open
------------- Nick
Date Posted: December 09, 2023 at 11:07 AM
Can I just slip the red black and tape it up? I cannot determine where it is.
I know it’s safety.
I also know nobody should be fooling around in a car with the astrostart live. Maybe a sticker saying NO HOOD PIN TURN VALET SWITCH OFF BEFORE BEGININNG WORK
------------- Nick
Date Posted: December 11, 2023 at 5:29 PM
You sure can.. Just cut the red black.. Your car your rules. I know in Canada, hood pins will rust out quickly.
