Compustar DC3 Flash, 2009 Hummer H2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147863
Printed Date: May 11, 2024 at 12:51 AM
Topic: Compustar DC3 Flash, 2009 Hummer H2
Posted By: muletime
Subject: Compustar DC3 Flash, 2009 Hummer H2
Date Posted: January 29, 2024 at 6:54 PM
Installing a Compustar DC3 with Compustar Pro R5 remotes and LTE Drone in a 2009 Hummer H2 (Std Key)
I'm struggling a bit with the firmware flash. Do I need all accessories (the Pro R5, Lte Drone...) plugged into DC3 module when flashing?
------------- Mule
Posted By: muletime
Date Posted: February 11, 2024 at 12:35 PM
Resolved. I unplugged everything and flashed. It took several attempts in the setup/flash to get it correct.
Compustar makes good stuff, but doesn't seem to have much love for the DIY garage warrior. Thankful for all the internet threads. With the T-Harness, this thing was unbelievably simply to install. The option setup and firmware flash took longer than the install.
Lock/Unlock, Proximity Unlock, Remote Start all work, and are a huge upgrade to the original 2009 GM equipment.
------------- Mule
