I am looking into installing a remote start/alarm on my 2000 Expedition and Looking at the vehicle diagrams requested the information indicated that this vehicle has a 5 wire positive Lock and Unlock system. Couldn't find out how to wire this on the site. Can anyone Help? Also if you have some helpful hints on installing a remote start and alarm on the 2000 Exp. that would be helpful as this is only my second time installing an alarm. Thanks
Mike:)
5 Wire Alternating 12 Volts Positive Door Locks-------------
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
Make: Ford
Model: Expedition
Year: 2000
This Database Was Last Updated On: 6/9/03
Index #: 1724
Alarm
Constant 12 volts YELLOW & GREEN/ VIOLET IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE/L GREEN IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) 16 PIN CONN. IN PASS. KICK PANEL
Trunk Pin Switch SAME CIRCUIT AS DOME LIGHT WIRE
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH *
Power Lock PINK / YELLOW PASSENGER KICK #201
Power Unlock PINK/L GREEN PANEL
* BROWN (+) Wire For Park Lights Is Also Found In A BLACK 66 Pin Connector In The Driver Kick Panel. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Thanks for your help. Can you tell me where to get the Negative pulse door lock diagram?
Mike
David,
Do you have the Remote start and stereo info as well?
You were misinformed on The 2000 Expedition.
This is a 3 wire (-) system. To test, find the pink / YELLOW, and pink/light-green wire in the drivers side kick panel. Once located, using a simple 12 volt test light, ground the clip to the chasis, and then probe one of these 2 wires. When you send a ground, throught the test light probe, it should lock/unlock depending on the wire probed.
This denotes a 3 wire door lock, just directly connect the (-) door lock outputs from your system to the corresponding wires in the truck. Done. If you find anything different, let me know, but it's doubtfull. Most every Expedition I have ever installed in was a Neg system.
Good Luck.
By the way, here is 5 wire reverse door locks from my site at www.RELAYHELP.com
Robert Martin/Owner
ALARMTEK ONLINE
www.ALARMTEKONLINE.com
so basically just take your r/s door lock wires and attach them correctly to the oppsing lock and unlock wires., and then tape them up test make sure lock is lock and so forth for unlock. thats it now relays no nothing .
Jon
Installer/Help Technician
---coral springs florida---
