Request: 1992 Mitsubishi Montero
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16872
Printed Date: June 11, 2024 at 2:27 AM
Topic: Request: 1992 Mitsubishi Montero
Posted By: prelude1481
Subject: Request: 1992 Mitsubishi Montero
Date Posted: July 30, 2003 at 8:18 AM
I need a "GOOD" wiring diagram for a 92 Montero - I checked the one on here vs. the one on bulldog's securitys web site and there are some differences with the accesory wire and the starter wire. I need a good reliable diagram so that I will be sure when I start this installation.
Thanks in advance,
Jeremy
Posted By: draasch
Date Posted: July 30, 2003 at 12:05 PM
do you have the sport???
here is what i have.
Make:   Mitsubishi
Model: Montero
Year:    1990-94
This Database Was Last Updated On:    6/9/03
Index #: 2752
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light GREEN/ RED OR RED / GREEN (-) AT PIN SWITCH
Trunk Pin Switch N/A
Parking Lamp GREEN / WHITE - AT FUSE BOX OR RED / WHITE AT RELAY
Power Lock BLACK/ RED AT CONNECTOR BEHIND #201
Power Unlock BLACK/ BLUE DRIVER SPEAKER
#201- See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal WHITE IGNITER ON REAR OF ENGINE-6 PIN PLUG
Ignition #2 BLUE/BLACK OR BLUE/ORANGE - IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BLUE OR BLUE / YELLOW IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN (+) AT SWITCH ON BRAKE PEDAL BRACKET
Reverse Light BLUE/RED (+) SWITCH ON TRANSMISSION @ BASE OF SHIFT LEVER
Rear Window Defrost N/A
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
