Constantly light security light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17223
Printed Date: June 08, 2024 at 9:23 AM
Topic: Constantly light security light
Posted By: oolowrideoo
Subject: Constantly light security light
Date Posted: August 06, 2003 at 5:08 AM
I've got a 2002 Grand AM GT, with a Viper 790XV. When I remote start or use the key, the security light comes on and stays on. I used the DEI bypass module for the PK2, but I'm still having the problem. I've tried everything I can think of to fix this... Resetting the alarm, disconnecting the battery overnight, re-learning the correct resistance, etc... I'm wondering if the car has a memory of the security violation, or if this is a real time thing. Can it just be reset by a dealership? I'm close to just pulling the bulb out of the dash. Any suggestions? Thanks in advance Ryan
Posted By: Velocity Motors
Date Posted: August 06, 2003 at 8:35 AM
You used the wrong bypass module forthis vehicle. Should have used: 555t or 555L.
------------- Jeff
Date Posted: August 10, 2003 at 7:01 PM
I used the 555L... any other suggestions? Thanks
Posted By: jrilla
Date Posted: August 12, 2003 at 1:22 PM
Take a look at Diagram #2 here if you are interested in a bypass method that uses a single relay and a resistor (or Trimpot).
Passlock II Temporary Bypass (Diagram 2)
The last '02 Grand Am I did I had to turn the key to start before hitting the brake after Remote Starting or else the security light would come on. There is a factory anti-grind feature on that year so you dont have to worry about grinding the starter. ------------- J Rilla
Owner/Installer
Posted By: floaterr
Date Posted: August 14, 2003 at 10:22 AM
Are you tunring the key all the way to the "start" or "crank" position when you get in? I was unaware that my first remote start had anti-grind feature and my Blazer would show the light when I just moved the key to "ign" (like the old days). Accidently watched wifes friend go all the way to "start" (even though she was told not to) and the security light didn't come on. Now I do the same thing and no more light.
Hope this helps.
Date Posted: August 15, 2003 at 1:55 PM
the light comes on even when I use the key.
Date Posted: August 15, 2003 at 1:56 PM
I used the realy and the resistor method, however it gave me problems... the resistor value will change with temperature.
Posted By: eurotek
Date Posted: August 16, 2003 at 9:28 PM
on grand am's it is almost inevitable. that security bypass will almost always fail eventually.. the DEI module is fine.. make sure you do not attempt to start the car with the yellow wire for passlock II cut.. that will definitely trigger the security light every time. to cancel out that light do the following - reconnect the yellow wire to original.
- disconnect the negative side of the battery only and wait 10-15 minutes
- i forget, either the key must be in the ignition but in the off position or it may need to be in the on position
- either way, only about 15 minutes
when ever you check the resistance value, you need to crank the key, make sure the yellow starter wire is cut so the car does not try to start, that is what causes the false light also, you might have the incorrect resistance here is what i do - with the starter wire cut
- first cut the yellow passlock (very thin) wire
- the other passlock wire, not the yellow, is your reference point
- meter the side of the yellow that goes to the key
- meter 2 to 3 times just to be sure
- once you have the resistance, connect the resistor from the yellow wire that is not on the key side and connect it to the black passlock wire, or whatever color it is in that vehicle. forget the bypass module
Date Posted: August 18, 2003 at 6:02 AM
Alright, I'm frustrated. I've tried every suggestion and I can't get the d@mn light to go off. Everything works fine, with remote start, and key start. The light is just on all the time. I'm trying to sell the car, and having the security light on is not helping. If there is anyone in northeast Ohio that wants to make a quick $100 please contact me. I need to get this taken care of, and I want it right. thanks, Ryan
Date Posted: August 19, 2003 at 5:29 AM
Should my car start without the yellow passlock wire connected? It will start with the key with the wire disconnected, however it will not start without the key.
Posted By: eurotek
Date Posted: August 25, 2003 at 10:00 PM
are you sure you have the correct wire? where did you find the wire? go behind the radio and yes, the car can start with that wire cut, but that is not a good thing. remove the remote start completely reconnect the yellow wire repair any other connections put the key in the ignition and turn to the on position.. do not start disconnect the negative on the battery and wait 10 minutes
if this doesnt work if neither do the trick, you are going to the dealer... or, remove the bulb that shows security.. LOL
Date Posted: August 26, 2003 at 8:46 AM
What's happening is really wierd. The last time I was messing with it, it would start remotely and with the key and the PK2 system in it original state. It worked fine like that for a couple weeks, now it won't remote start anymore. I ordered a PLdata bypass module that I'm expecting will cure all of my problems. Thanks everyone for the help. Ryan
