2000 pontiac sunfire help!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17922
Printed Date: February 09, 2026 at 6:07 PM
Topic: 2000 pontiac sunfire help!
Posted By: capone
Subject: 2000 pontiac sunfire help!
Date Posted: August 21, 2003 at 9:35 PM
Installing a remote alarm & starter, got power dash and parking lights come on need help with factory alarm, where is it and what wires to the alarm, ignition # 2 cause it doesnt have one, what is aux 2 output (-) for, and where to put the ground output when running at ???? any info will help, THANKS
Posted By: floaterr
Date Posted: August 22, 2003 at 8:06 AM
what kind of alarm?
search for sunfire and you'll find info for the model before and after that should be close to the same wiring.
Posted By: eurotek
Date Posted: August 23, 2003 at 8:23 PM
there is no factory alarm on a sunfire
maybe a keyless entry, but no alarm
there is however a passlock II system that needs to be bypassed,
no second ignition but there is Pink for ignition, and Orange for accessory, those need to be activated along with the starter wire...
DO NOT try to crank the car with the starter wire connect when testing for resistance to bypass Passlock II
Posted By: patmar
Date Posted: August 23, 2003 at 8:53 PM
for sunfire i think have second ing wire is a white (for ecu trans)check in color code
