Positive door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17959
Printed Date: February 09, 2026 at 12:07 AM
Topic: Positive door locks
Posted By: LordofShadows
Subject: Positive door locks
Date Posted: August 22, 2003 at 6:00 PM
Hello this is my first install, I have simple question reguarding the door locks. The car has two locking wires, one lights my test light Only when the lock button is being pressed. The other lights only when the unlock button is pressed. The car alarm has two negative 200ma lock wires. Im pretty sure I need two relays, Just I dont know how to wire them. If one of your fine 12volt forum readers could tell me which wires go to what on the relay, or point me in the direction to the correct wiring chart on this webpage. (I was looking at the 3 wire positive chart on this site but wanted to be totaly sure)
One other thing, this car alarm has a starter disable function that requires me to cut the main starter wire. I did so and connected the wires with a large yellow couplings, I later started the car and noticed that it took much longer for the engine to start (before a slight tap of the key would start the car) and after the long start (~1 second) I smelt strong gas fumes from the car (catalic converter *should* of taking care of anything) I was just wondering whats the best way to connect these large gauge wires? I wouldnt want to damage the car due to this car alarm. But It only did this once so im hoping it doesnt reoccur.
Posted By: jrilla
Date Posted: August 22, 2003 at 6:09 PM
Thats the one you need: The 3 wire positive diagram.
J Rilla
Owner/Installer
