2001 Toyota Tundra Alarm Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17977
Printed Date: February 08, 2026 at 9:14 PM
Topic: 2001 Toyota Tundra Alarm Install
Posted By: Kbahjat
Subject: 2001 Toyota Tundra Alarm Install
Date Posted: August 23, 2003 at 11:00 AM
I need to put a keyless entry / alarm system in my 2001 Tundra Limited. I can find the factory rs3000 systems on the web, but can't find install instructions. It looks like they just snap into the existing wiring harnesses.
Does anyone have an install document for one of these systems? I think the Tundra and Sequoia would be the same.
thanks.
Posted By: Scott35
Date Posted: August 23, 2003 at 2:32 PM
If you get one off of ebay they usually are new and come with the install instructions. You may be able to use a RS3200. Each individual Toyota usually takes a different main harness.
Tacomacrew
Posted By: Kbahjat
Date Posted: August 30, 2003 at 9:03 AM
Thanks Scott,
I went ahead and got the system, and it has a xeroxed copy of the Toyota factory install manual.
Now we'll see if I can get this sucker wired in without destrying my truck! ;-)
thanks again.
Posted By: michaeltam2k
Date Posted: September 22, 2003 at 7:28 PM
do you guys know with wire is the factory alarm disarm and the arm wire to my 03' sequoia . thanks in a million guys for your help .
