i got this
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18107
Printed Date: February 06, 2026 at 4:38 PM
Topic: i got this
Posted By: davywavy4186
Subject: i got this
Date Posted: August 26, 2003 at 1:46 PM
https://cgi.ebay.com/dll?ViewItem&item=3041803023&category=14934 i ended up ordering this one can i get some honest opions on it i probably shoulda b4 but o well sh*t happens thanx
Posted By: profuse007
Date Posted: August 26, 2003 at 2:16 PM
well since you ordered already, why dont you try it out and let the ppl know how it goes.
------------- Houston,TX
Posted By: jrilla
Date Posted: August 26, 2003 at 3:29 PM
Those units are great, you should be very pleased at that price. The install manual stinks but you should be able to get her installed eventually. Leave your self a good chunk of time if it your first install and do a lot of prep work on the wires before gettung under the dash or you will end up with a mess under there. Gte a good wire diagram for your car and study it.
Good luck, let us know how you like it.
------------- J Rilla
Owner/Installer
Date Posted: August 26, 2003 at 8:02 PM
does anyone know were i can get a wiring diagram for a 98 pontiac sunfire
Date Posted: August 26, 2003 at 9:02 PM
all the diagram prior to 2000 will listed on this site. diagram under general column.
Posted By: 10nesne1
Date Posted: August 27, 2003 at 7:28 PM
Here is the wiring diagarm. Good luck
PONTIAC SUNFIRE 96-98
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED(2)
IGNITION HARNESS
IGNITION 1 PNK IGNITION HARNESS
IGNITION 2 WHT
IGNITION HARNESS
IGNITION 3 NA
IGNITION HARNESS
ACCESSORY /HEATER BLOWER 1 ORG IGNITION HARNESS
ACCESSORY /HEATER BLOWER 2 N/A N/A
STARTER YEL IGNITION HARNESS
PARKING LIGHTS BRN(+) AT HEADLIGHT SWITCH
DOMELIGHT L GRN/BLK(-) CONVENIENCE CENTER MOD
PWR DOOR LOCK L BLU EITHER KICK PANEL MUST TEST FROM PASS SWITCH
PWR DOOR UNLOCK WHT IF FACT KEYLESS TYPE A W/O FACT KEYLESS TYPE C
TRUNK RELEASE BLK/WHT(+) OEM KEYLESS MOD IN TRUNK
TACH SENSOR WHT AT POWERTRAIN CONT MOD
BRAKE
WHT(+) SW ABOVE BRAKE PEDAL
HORN
BLK(-)
STEERING COLM
FACTORY DISARM
NA
IN SCHEMATICS
FACTORY ANTI-THEFT
PASSLOCK I
