Towed after installing remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18180
Printed Date: February 06, 2026 at 6:33 AM
Topic: Towed after installing remote start
Posted By: Port
Subject: Towed after installing remote start
Date Posted: August 27, 2003 at 9:01 PM
I had a customer come in today complaining about a alarm install that was done at some other shop we have never heard of ...........he told us after they tried to use the remote start on a 2001 Ford Explorer Sport it had to be towed to the Ford dealership to be re-programmed...........and now wants us to install a alarm in it with remote start, window module, and a microwave sensor..........My question is this..........What could this other shop have done other than the obvious?...........Customer says the key is chipped and the place used a transponder but it still fried his computer. Is there some "magical installation" tip we are supposed to know .......... We have done chipped and resistor based vehicles and never had a problem like that.......
Thanks for any replies
Posted By: vaderfop
Date Posted: August 27, 2003 at 9:28 PM
Where did that other shop hook up the tach wire for the remote start? I saw a car once that got it's computer fried from the wrong tach wire.
Posted By: Port
Date Posted: August 27, 2003 at 10:01 PM
I dont know where they got the tach wire because the customer had them take everything out ............. But i did look at the tach wire i assume it is the tan with yellow wire and it did not look touched..... no t-tap marks or anything ................so maybe they used the voltage sense option on the alarm or they hooked it up to the wrong wire as you said .............. I dont know what kind/brand of alarm it was either ...............I just dont want to make the same mistake after I have done so many and i have gotten so comfortable with doing them and there is something I am missing on this one
Posted By: floaterr
Date Posted: August 28, 2003 at 8:48 AM
Hate to be negative but seems to me most people (now not all just most) would get a bad taste in their mouth about remote starters (or any alarms) if it "fried the computer". That had to be one big reapir bill too. I question if the person was lieing and had something else go wrong and blamed it on the remote start. They might end up being more headache then it's worth
Also they stated that they themselves tried the remote start and it fried the puter? So the techs installing it NEVER test started it? Sounds kinda fishy..
Sorry again and Good Luck...
Posted By: zargon
Date Posted: August 28, 2003 at 12:13 PM
it may have nothing to do with the remote start but may be a defective part in the truck you never know, it could of been a very bad install,
zargon ruler of estranorth
Posted By: chpsk8
Date Posted: August 28, 2003 at 3:39 PM
I guess I would pass on that customer. Not worth the risk if you are not comfortable. Who knows what wires were  scrambled under the dash due to previous work by either a real installer or just a regular guy trying to save a buck. Pass them on to the local Best Buy!
Posted By: JWorm
Date Posted: August 28, 2003 at 7:46 PM
Maybe the other shop permanately bypassed the transponder key by removing a chip out of a key and glueing it near the key cylinder. I've seen it done by other shops. Maybe the truck saw two keys at once and deleted them both and that is what had to be reprogrammed.
Posted By: auex
Date Posted: August 28, 2003 at 9:21 PM
I have seen that problem before. If the shop removed the "pellet" from one key and not the other, then if the customer tried to use the key that still had the pellet in it then the vehicle wouldn't start. If the bcm fried then I would steer clear of this one, if all that needed to be done was to reprogram the keys, then use the correct immobilizer defeat and it should be fine.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
