Clifford Concept 50
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18233
Printed Date: February 07, 2026 at 6:59 AM
Topic: Clifford Concept 50
Posted By: RST_lee
Subject: Clifford Concept 50
Date Posted: August 29, 2003 at 12:33 PM
Can some one please help. I was driving home from work and the control box stated clicking.
Now the alarm will not disarm. I assume its lost a supply from some where.
Has any one got a wire plan or can any one help
REGARDS
RST_LEE
Posted By: elrayodesinaloa
Date Posted: August 29, 2003 at 6:55 PM
concept 50 is an old alarm system way too obsolete now, so I figure the installation was performed years ago. You should check your constant 12v wire and ground first, those are the first things that give up as time passes since terminals corroed due to enviroment etc... also check that the battery on the remote is fresh.
