96 Mitsubishi Legnum locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20274
Printed Date: May 18, 2024 at 11:29 AM
Topic: 96 Mitsubishi Legnum locks
Posted By: cool_greg
Subject: 96 Mitsubishi Legnum locks
Date Posted: October 18, 2003 at 4:35 PM
My brother has a 96 Mitsi Legnum, R/H drive and had an alarm installed by somebody, but they never hooked up the power lock, does anyone know where and what colours they are, i know that the switch on the drivers door uses some kind of databus system as there are only about 5 wires for all 4 power windows and locks, but I can hear relays click when the lock/unlock button is pressed and hope to tie into those somehow.
------------- Just a Guy, Wiring up those Vehicals
Gool_Greg
Posted By: Velocity Motors
Date Posted: October 18, 2003 at 5:56 PM
When he manually locks the door on the driver's side, does the passenger side lock too ? If it does, then the vehicle has central door lock system and you will need to add a relay. Some of the older Mit/Plymouth/Eagle's have this system so maybe your car does too.
------------- Jeff
